[postgis-devel] text(lwgeom)
Carl Anderson carl.anderson at vadose.org
Mon Dec 13 18:24:48 PST 2004
I believe that text(lwgeom) is necessary if we want a WKB-ish CSTRING
format to be the default
representation for a geometry in scripting.
Inside PLPGSQL I have found that I need to
FOR a in EXECUTE \'select mytab.the_geom
          from mytab,
                 (select geometry(\'||quote_literal(text(GEOM))||\') as
the_geom ) as e
              where
                   mytab.the_geom && e.the_geom and
                   intersects(mytab.the_geom, e.the_geom)\'  LOOP
       blah;
       blah;
END LOOP;
in this instance I expect that text(GEOM) ==  the CSTRING rep of a LWGEOM
but in a TEXT wrapper.
This would cause
       text(LWGEOM)          text rep of CSTRING representation
       astext(LWGEOM)       OGIS WKT rep
       asbinary(LWGEOM)   OGIS WKB rep
I can't
   setsrid(geometry(asbinary(\'||asbinary(GEOM)||\')),\'||mysrid||\')\'
because there does not exist a clear path from BYTEA to TEXT or BPCHAR;
And the precision issues with WKT vs WKB need to be quickly eliminiated when
trakicg down a problem.
Such a text(geometry) would simply be
 text-izing LWGEOM_out as the attached patch exhibits.
C.
ps.
postgis-devel seems dead-ush.  Should this discussion occur in
postgis-users??
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20041213/9628661b/attachment.bin>
