[postgis-devel] RE: join selectivity
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Tue Dec 14 02:15:14 PST 2004
Hi strk,
Could you post the explain outputs for those queries too? I don't see why
with an index scan consideration between two columns that the planner has to
invoke four RESTRICT functions?
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
> -----Original Message-----
> From: strk at refractions.net [mailto:strk at refractions.net]
> Sent: 13 December 2004 17:13
> To: Mark Cave-Ayland
> Cc: postgis-devel at postgis.refractions.net;
> pgsql-hackers at postgresql.org
> Subject: Re: [postgis-devel] RE: join selectivity
> On Mon, Dec 13, 2004 at 03:04:01PM -0000, Mark Cave-Ayland wrote:
> > Hi strk,
> > > Sent: 13 December 2004 14:05
> > > On Mon, Dec 13, 2004 at 12:16:15PM -0000, Mark Cave-Ayland wrote:
> > > > Hi strk,
> > > > (cut)
> > > > > > Taking a look at join selectivity...
> > > > > > For a query like this:
> > > > > >	SELECT id FROM table1, table2
> > > > > >	WHERE table1.geom && table2.geom;
> > > > > > RESTRICT selectivity is invoked twice and
> > > > > > JOIN selectivity is invoked once.
> > > > > > The RESTRICT code is not able to find a costant
> part and thus
> > > > > > returns the default value (0.000005), JOIN
> selectivity so far
> > > > > > returns an hard-wired 0.1.
> > > > > > Questions:
> > > > > > (1) What should RESTRICT selectivity do in this case ?!
> > > > > Maybe that's how the planner decide what to do:
> > > > > 	1) sequencially scan table1 and use index for each row
> > > > > (RESTRICT)
> > > > > 	2) sequencially scan table2 and use index for each row
> > > > > (RESTRICT)
> > > > > 	3) ... some other magic I'm missing .. (JOIN)
> > > > Indeed, you could be on the right lines here in thinking
> > > the planner
> > > > considers some form of individual scan on each first before
> > > finalising
> > > > on a plan type (although unless the tables are small I
> would have
> > > > thought this would not have been an option). Does this
> > > change if you
> > > > do a SET ENABLE_SEQSCAN = 'f' before the query?
> > > Bingo.
> > > Both ENABLE_SEQSCAN = 'f' or unavailability of an index make
> > > the selectivity estimator calls go away. The join selectivity
> > > is called nonetheless (also in absence of indexes).
> > Right. So what you're saying is that if there is *no* GiST index on
> > *one* of the geom columns, or sequential scans are
> disabled, then the
> > calls to RESTRICT go away?
> Index on a single table makes 2 calls to RESTRICT:
>   strk=# select * from test1, test2 where test1.geom && test2.geom;
>   NOTICE:  LWGEOM_gist_joinsel called (returning 0.000005)
>   NOTICE:  LWGEOM_gist_sel called
>   NOTICE:   no constant arguments - returning default selectivity
> Index on a both table makes 4 calls to RESTRICT:
> No index makes no calls to RESTRICT:
> > > > It just seems strange for a <column> <operator>
> <column> clause to
> > > > call a function involving a constant. Again, I'd
> probably ask on
> > > > pgsql-hackers just to clarify - I think Tom Lane was
> > > involved with the
> > > > planner, so will be able to answer this one fairly quickly.
> > CCd to pgsql-hackers for clarification. BTW which version are you
> > developing against - 7.4 or 8.0?
> 8.0.0RC1
> --strk;
> > Kind regards,
> > Mark.
> > WebBased Ltd
> > Tamar Science Park
> > Plymouth
> > PL6 8BT
