[postgis-devel] polygonize
strk at refractions.net
Sun Dec 19 09:49:33 PST 2004
On Sun, Dec 19, 2004 at 11:22:09AM -0500, Carl Anderson wrote:
> Since polygonize() seems to able to act as a general polygon cleaning
> function
> how about adding a direct function to call it, in addition to the
> aggregate form.
> update shapes set the_geom = polygonize(the_geom);
> so we don't have to
> update shapes set the_geom = f.new_geom
> from ( select polygonize(the_geom) as new_geom, gid
> from shapes
> group by gid ) as f
> where
> f.gid = shapes.gid;
If you find it useful I don't see why not.
The point is I didn't much exploit capabilities of polygonize().
> btw
> select polygonize_garray(array_append('{}',the_geom) from shapes;
> Causes a backend ABEND;
Does collect_garray(array_append('{}',the_geom) from shapes work ?
--strk;
> C.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
