[postgis-devel] Re: [postgis-users] usage of AddGeometryColumn etc.
strk
strk at keybit.net
Tue Jun 1 04:39:05 PDT 2004
On Tue, Jun 01, 2004 at 01:19:47PM +0200, Hubert Fröhlich wrote:
> Hi list,
> I have a table with a geometry column.
> test=# create table demo(col1 text);
> test=# select AddGeometryColumn('', 'demo',
> 'pgpoly','31494','MULTIPOLYGON',2);
> addgeometrycolumn
> Geometry column pgpoly added to table public.demo WITH a SRID of 31494
> and type MULTIPOLYGON
> (1 row)
> When I drop the table without dropping the geometry column first
> test=# drop table demo;
> DROP TABLE
> test=# select * from geometry_columns;
> f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
> coord_dimension | srid | type | attrelid | varattnum | stats
> | public | demo | pgpoly
> | 2 | 31494 | MULTIPOLYGON | 5391696 | 3 |
> (1 row)
> I learn that DROP TABLE did not remove my geometry fully - I have to
> - either delete the entry in geometry_columns.
> - or execute a DropGeometryColumn(....) before DROPing the table.
> a) It would be quite comfortable just DROPping tables ... Is it intended
> or possible to improve the functions this way?
Not intended.
Postgresql guys does not approve triggers on system catalogues.
Maybe, the next AddGeoemtryColumn call could 'detect' those
spurious records in geometry_columns and get rid of them, or
just always replace records there.
What users think `bout this ?
---strk;
> b) If this is not possible, some hint in the documentation would be
> useful .
> Regards,
> Hubert
> Dr.-Ing. Hubert Fröhlich
> Bezirksfinanzdirektion München
> Alexandrastr. 3, D-80538 München, GERMANY
> Tel. :+49 (0)89 / 2190 - 2980
> Fax :+49 (0)89 / 2190 - 2997
> hubert dot froehlich at bvv dot bayern dot de
> postgis-users mailing list
