[postgis-devel] Re: [postgis-users] usage of AddGeometryColumn etc.
David Blasby
dblasby at refractions.net
Tue Jun 1 09:12:04 PDT 2004
strk wrote:
> Again, triggers on system tables are not seen with simpaty.
> If you guys write down every occurrence of the stale record problem
> we can find out an ad-hoc solution (like adding check in AddGeometryColumn
> which I think is the one function making noise about it).
> --strk;
> PS: I've just committed changes in the postgis.sql.in file to make
> find_extent and build_histogram2d (and update_geometry_stats)
> better support schema in the way you suggested.
One way would be to make a geometry_columns_meta table with all the
information in it (like we have now). Then have geometry_columns be a
view that crosses the system table with the geometry_columns_meta table.
This will hide any "stale" rows.
Alternately, you could have AddGeometryColumn() behave smarter - it
should automagically delete any stale columns in the current
geometry_columns table (or the future geometry_columns_meta table).
dave
