[postgis-devel] schema aware functions
strk strk at keybit.net
Tue Jun 1 09:15:58 PDT 2004
On Fri, May 21, 2004 at 03:07:57AM +0000, Carl Anderson wrote:
> for consideration for schema aware Postgresql versions
> update geometry is a replacement
> build_histogram2d is a new fcn (new prototype)
> find_extent is a new fcn (new prototype)
> It works for me (TM)
> the existing functions presume that all geometry tables are accesible
> through the search_path.  These fcns are based on f_table_schema.
> f_table_name.
I've committed own-grown version of the function you suggested,
profitting to make some cleanup and shrinking of code.
Please try current CVS and see if it still works for you :)
Note that the update_geometry_stats(table, geom) still works
the old way (as the signature suggests).
--strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
