[postgis-devel] Infinite coordinates in geometries
strk
strk at keybit.net
Wed Jun 2 17:05:55 PDT 2004
I've found the bug in the postgis picksplit function.
This function is the exact copy of rtree_picksplit from rtree_gist,
so this might be of interest to the rtree_gist guys as well.
To determine destination of the node, this kind of checks are performed:
cur->low.y - pageunion.low.y < pageunion.high.y - cur->high
cur->low.y - pageunion.low.y > pageunion.high.y - cur->high
cur->low.y - pageunion.low.y == pageunion.high.y - cur->high
Substracting Inf from Inf gives Nan, which does not match any
of the checks.
I've currently (CVS) made the == check (equality) the default,
so to have Infinite valued keys be cached by an ADD-TO-LESS-POPULATED
rule.
I dunno the consequences of this in terms of overall index functionality,
but you don't get the error message anymore ;)
I'm afraid Infinite geometry presence in a GiST index makes the index
unusable because it eventualy ends up with an infinite plane as root
node and with an arbitrary tree built under it.
Maybe the picksplit function or whatever other GiST
construction function invoked at every new inserted geometry or at
while table scan should warn the user, or skip infinite geometries
(making them invisible by the index).
Any comment from GiST friends ?
--strk;
On Tue, Jun 01, 2004 at 10:14:55AM -0700, Paul Ramsey wrote:
> Quoting strk <strk at keybit.net>:
> > On Tue, Jun 01, 2004 at 10:00:02AM -0700, Paul Ramsey wrote:
> > > No, they shouldn't create Inf geometries.
> > > It's 'POINT(Inf Inf)'::geometry, no comma, BTW.
> > > P.
> > Oops... it works, sorry :)
> > Now, what should I do ?
> > Drop Inf geometry support or use it to find other bugs ?
> I think we should drop it, what are your thoughts? If we leave it in, there is
> an implied rational behavior to apply in the presence of these things which
> could be very hard to figure out. I suppose from an indexing point of view they
> are no worse than NULL geometries in semantic terms.
> > The operation our guy was trying to execute is not specified,
> > I tried filling a table with Inf points, building a gist index,
> > querying it... no memory alloc problems so far.
> > --strk;
> > > > On Tue, Jun 01, 2004 at 09:53:04AM -0700, Paul Ramsey wrote:
> > > > > Intriguing... doing POINT(Inf,Inf) does not do the trick? I would have
> > > > thought
> > > > > that a2d() would interpret the Inf token properly.
> > > > > P.
> > > > test=# select 'POINT(Inf, Inf)'::geometry;
> > > > ERROR: couldnt parse object in GEOMETRY
> > > > If John Hagstrand could reproduce the Inf geoms that would help...
> > > > I think the bug is actually there.. postgis functions should not
> > > > produce such geoms, should 'hem ?
> > > > --strk;
> > > > > > On Tue, Jun 01, 2004 at 09:13:33AM -0700, Paul Ramsey wrote:
> > > > > > > Sandro,
> > > > > > > Could you check for a reasonable place to handle this special case?
> > I
> > > > do
> > > > > > not
> > > > > > > think Inf geometries are something we want to handle, necessarily
> > > > > > > Paul
> > > > > > The question is: how did this Inf geometry get created ?
> > > > > > I dunno how to make one, for debugging purposes...
> > > > > > --strk;
> > > > > > > ----- Forwarded message from john.hagstrand at interageresearch.com
> > > > > > > Date: Tue, 1 Jun 2004 10:59:32 -0500
> > > > > > > From: John Hagstrand <john.hagstrand at interageresearch.com>
> > > > > > > Reply-To: John Hagstrand <john.hagstrand at interageresearch.com>
> > > > > > > Subject: RE: [GENERAL] ERROR: invalid memory alloc request size 0
> > > > > > > To: Paul Ramsey <pramsey at refractions.net>
> > > > > > > Hello Paul,
> > > > > > > I solved this problem.
> > > > > > > I had 20 or 30 records in that table with a geometry column like
> > this:
> > > > > > > POINT(-inf -inf). I deleted those records, and then dropped and
> > > > recreated
> > > > > > > the index. That solved the problem. I can now do inserts and
> > updates
> > > > > > > without getting the malloc error.
> > > > > > > Thanks for your help.
> > > > > > > I look forward to seeing you in Ottawa next week.
> > > > > > > John
> > > > > > > > -----Original Message-----
> > > > > > > > From: Paul Ramsey [mailto:pramsey at refractions.net]
> > > > > > > > Sent: Thursday, April 15, 2004 10:49 PM
> > > > > > > > To: John Hagstrand
> > > > > > > > Cc: Tom Lane; dblasby at refractions.net
> > > > > > > > Subject: Re: [GENERAL] ERROR: invalid memory alloc request size 0
> > > > > > > > John,
> > > > > > > > A pg_dump would be sufficient, or a shape file, and a SQL log of
> > the
> > > > > > > > commands you ran.
> > > > > > > > Thanks!
> > > > > > > > Paul
> > > > > > > > On Thursday, April 15, 2004, at 12:27 AM, John Hagstrand wrote:
> > > > > > > > > Hello Paul,
> > > > > > > > > Thanks for helping. I'd like to send you the test data set.
> > > > > > > > > What format would you like?
> > > > > > > > > John
> > > > > > > > >> Sent: Wednesday, April 14, 2004 11:28 PM
> > > > > > > > >> To: Tom Lane
> > > > > > > > >> Cc: John Hagstrand; dblasby at refractions.net
> > size 0
> > > > > > > > >> We'll need the test data set that does this, of course, and
> > some
> > > > > > > > >> version info. The indexing routines seemed pretty solid
> > (tested on
> > > > > > > > >> many
> > > > > > > > >> many millions of geometries), I am surprised this has come up.
> > > > > > > > >> P.
> > > > > > > > >> On Wednesday, April 14, 2004, at 08:53 PM, Tom Lane wrote:
> > > > > > > > >>> "John Hagstrand" <john.hagstrand at interageresearch.com>
> > writes:
> > > > > > > > >>>> Here is a more detailed backtrace.
> > > > > > > > >>>> (gdb) bt
> > > > > > > > >>>> #0 errfinish (dummy=0) at elog.c:319
> > > > > > > > >>>> #1 0x081a85de in elog_finish (elevel=20,
> > > > > > > > >>>> fmt=0x8231d80 "invalid memory alloc request size %lu")
> > at
> > > > > > > > >>>> elog.c:853
> > > > > > > > >>>> #2 0x081b3dd6 in MemoryContextAlloc (context=0x9f10598,
> > size=0)
> > > > at
> > > > > > > > >>>> mcxt.c:482
> > > > > > > > >>>> #3 0x0807411d in gistSplit (r=0xbe9a1938, buffer=805,
> > > > > > > > >>>> itup=0x9f25128,
> > > > > > > > >>>> len=0xbfec3eac, giststate=0xbfec4070, res=0xbfec402c) at
> > > > > > > > >>>> gist.c:1348
> > > > > > > > >>> Okay, this makes it pretty clear that the problem is the
> > > > picksplit
> > > > > > > > >>> function is setting v.spl_nleft to zero. In other words it's
> > > > failed
> > > > > > > > >>> to "split" the page at all (everything in the original index
> > page
> > > > has
> > > > > > > > >>> gone into the righthand child). This seems to me to be
> > > > necessarily
> > > > > > > > >>> a bug in the index opclass's picksplit function.
> > > > > > > > >>> You previously said that the column in question is a PostGIS
> > > > Geometry
> > > > > > > > >>> column, so I'm of the opinion this is a PostGIS bug. (Paul,
> > any
> > > > > > > > >>> suggestions about how to probe deeper?)
> > > > > > > > >>> regards, tom lane
> > > > > > > > >> Paul Ramsey
> > > > > > > > >> Refractions Research
> > > > > > > > >> Email: pramsey at refractions.net
> > > > > > > > >> Phone: (250) 885-0632
> > > > > > > > Paul Ramsey
> > > > > > > ----- End forwarded message -----
