[postgis-devel] lwgeom compile problem
strk
strk at keybit.net
Fri Jun 4 08:28:21 PDT 2004
On Fri, Jun 04, 2004 at 10:43:38AM -0400, Carl Anderson wrote:
> strk wrote:
> >Thanks Carl !
> >This is the same problem I had.. now we know how to fix it :)
> >Changing YACC in the local Makefile is not a good idea, since
> >postgresql detected YACC is *detected*, while we are only assuming...
> >I copied pgsql style, explicitly renaming y.tab.c and y.tab.h
> >to wktparse.tab.c and wktparse.tab.h. This is YACC naming
> >convention after all...
> >I've also added some prototypes to reduce compiler warnings
> >(yet to be completely removed)
> >And... I've put the following files in .cvsignore:
> > liblwgeom.so.0.1
> > lwgeom.sql
> > wktparse.tab.c
> > wktparse.tab.h
> > lex.yy.c
> >Do you think it's correct ?
> still not working for me with YACC as "bison -y"
> so I edited wktparse.y like this
> a_point : point_2d | point_3d | point_4d ;
> point_2d : VALUE VALUE {alloc_point_2d($1,$2) ;};
> point_3d : VALUE VALUE VALUE {alloc_point_3d($1,$2,$3) ;};
> point_4d : VALUE VALUE VALUE VALUE {alloc_point_4d($1,$2,$3,$4) ;};
> empty : EMPTY {alloc_empty() ;} ;
> I got a error free compile
> Testing:
> run_regress and run_regress3 are ok
> but run_regress2 bombs and causes a server abend on
> select astext("POINT()'::LWGEOM) as geom;
> could you add to Makefile
> OTHERS=y.output lex.yy.c wktparse.tab.c wktparse.tab.h lwgeom.sql
> clean distclean maintainer-clean: clin-lib
> @rm -f $(OBJS)
> @rm -f $(OTHERS}
I've committed the changes in wktparse.y
and Makefile.
Did not run regression tests yet ..
I'll let you know.
--strk;
> Carl Anderson
> GIS Manager Fulton County, Georgia
> carl.anderson at co.fulton.ga.us
> 404.730.8026
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
