[postgis-devel] lwgeom: regress tests
David Blasby dblasby at refractions.net
Tue Jun 8 09:01:59 PDT 2004
strk wrote:
> All regress tests run with no problems for me.
> Just a note. I do not have a 'postgres' user, so I had
> to remove the \c line on top of regres_lots_of_points.sql
> If this is not a problem I'd remove the 'You are now connected as...'
> line from the expected result.
This is fine to do.
There could possibly be permission problems, but they should be pretty
obvious and easy to correct.
dave
