[postgis-devel] RE: standard deviation based histogram extent reduction
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Fri Jun 11 00:14:59 PDT 2004
Hi strk,
> -----Original Message-----
> From: 'strk' [mailto:strk at keybit.net]
> Sent: 10 June 2004 20:01
> To: Mark Cave-Ayland
> Cc: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] RE: standard deviation based
> I've added irregular sized histogram grid (cell aspect is
> always nearly square keeping total cells near to requested precision).
> I'd like to have some test results before working on other
> refinements. Just to make sure we are not introducing any bug.
> Thanks for you attention.
> --strk;
The irregular sized histogram code looks good to me.
The only improvement I was suggesting was that instead of considering
the cutoff rectangle as being the overall histogram extent, we should
recalculate the histogram extent ignoring everything outside of this
rectangle. This would have the result in most cases of bringing in the
histogram extent much "tighter" around the dataset and hence increase
the accuracy - other than changing the histogram extents, it won't
change any of the existing code or methodology.
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
