[postgis-devel] Re: sql files proliferation
strk
strk at keybit.net
Mon Mar 1 06:19:58 PST 2004
pramsey wrote:
> Confusingly, I have yet to find *any* way to call cpp that works. In
> fact, it does not appear to work the way the man page says it should...
> it resolutely refuses to write an output file.
> Still trying.
> P.
Does it write to stdout ?
I don't see any problems in using shell redirects...
--strk;
> On Sunday, February 29, 2004, at 02:43 PM, strk wrote:
> > pramsey wrote:
> >> OS/X cpp chokes for reasons I have yet to tease out. Probably not a
> >> good sign for platform portability...
> >> cpp: Too many arguments
> > We could either find the right way to call CPP (autoconf?)
> > or maybe opt for a perl script, since this is already required,
> > to perform basic cpp (traditional) work.
> > --strk;
> >> On Saturday, February 28, 2004, at 06:52 AM, strk wrote:
> >>> I've added an experimental source sql file and a corresponding rule
> >>> in the Makefile. CPP call is with -traditional-cpp flag, which
> >>> is nicer with multiline strings and '--' comments.
> >>> If you can give it a try we can test for compatibility.
> >>> Run make postgis_new.sql (it's not built by default) to
> >>> get postgis_new.sql generated from postgis.sql.in.
> >>> The source file (postgis.sql.in) is not optimized to use
> >>> cpp features, it just a copy of all the files previously
> >>> used wrapped in #if USE_VERSION == <ver> blocks.
> >>> Runnign a diff between postgis.sql and postgis_new.sql should
> >>> give you just comments, blank lines and the postgis_version()
> >>> function with double quotes ('') instead of slash escaped (/')
> >>> quote inside the SQL function.
> >>> --strk;
> >>> strk wrote:
> >>>> pramsey wrote:
> >>>>> I wonder if we can use cpp and simple #ifdef stuff to do the
> >>>>> preprocessing. Would be nice.
> >>>>> P.
> >>>> I made some use of cpp with languages other then C.
> >>>> The main problem is that cpp thinks #-lines are overlooked byt
> >>>> the compilers. GNU cpp version accepts -P to omit linemarkers
> >>>> -P Inhibit generation of linemarkers in the output from
> >>>> the preprocessor. This might be useful when running
> >>>> the preprocessor on something that is not C code, and
> >>>> will be sent to a program which might be confused by
> >>>> the linemarkers.
> >>>> ... but that could not be always the case.
> >>>> Can people try that (or similar) to solve the linemark problem ?
> >>>> --strk;
> >>>>> strk wrote:
> >>>>>> The postgis*sql* files are becoming a major part
> >>>>>> of the distribution (as number of files).
> >>>>>> What about having a single sql for each postgres version ?
> >>>>>> Or - better - use some preprocessing to keep in common
> >>>>>> things that are common and spilt things that need to be
> >>>>>> splitted ?
> >>>>>> I need to move geometry_column creation out of _common_
> >>>>>> into each of version-specific files because for PG75 there
> >>>>>> is no need of attrelid oid, varattnum int and stats histogram2d;
> >>>>>> this already happended for schema support changes
> >>>>>> (addGeometryColumn,
> >>>>>> dropGeoemtryColumn, fix_geometry_columns) and is getting boring.
> >>>>>> --strk;
> >>>>> __
> >>>>> | Paul Ramsey
> >>>>> | Refractions Research
> >>>>> | Email: pramsey at refractions.net
> >>>>> | Phone: (250) 885-0632
> >>>>> \_
> >>>>> _______________________________________________
> >>>>> postgis-devel mailing list
> >>>>> postgis-devel at postgis.refractions.net
> >>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> >> Paul Ramsey
> Paul Ramsey
