[postgis-devel] Re: geometry stats
strk
strk at keybit.net
Mon Mar 1 08:07:55 PST 2004
m.cave-ayland wrote:
> Hi strk,
(cuts)
> > > The one thing that was apparent from the above was that we
> > currently
> > > need to increase the number of boxesPerSide when the
> > statistic target
> > > is increased, since the implication is that users would
> > increase this
> > > number if greater accuracy were required. Since the default
> > values of
> > > 40bps with a target of 10 worked quite well, it may be worth using
> > > this ratio as the basis of the boxesPerSide calculation, e.g.
> > > boxesPerSide = sqrt(150 * statistics target);
> > > This gives values 38 for the default value of 10, and a
> > value of 388
> > > if someone is concerned enough to use the maximum.
I've committed the change. It uses 40 to 400 boxesPerSide.
(just to keep current 40x40 default).
--strk;
