[postgis-devel] Re: geometry stats
strk
strk at keybit.net
Thu Mar 4 03:41:58 PST 2004
On Thu, Mar 04, 2004 at 10:51:55AM -0000, Mark Cave-Ayland wrote:
(cuts)
> 2) Yesterday I tried lots of tests comparing the box_overlap() function
> with strk's
> pg_boxoverlap but for me both tests always returned the same results.
> strk,
> can you provide Dave with a case that fails as I can't replicate a
> problem
> here? Since I can't find a problem in the code then I've reverted
> back to the
> old box_overlap() code just to keep everything consistent...
Unfortunately I haven't kept track of it, anyway
I could have seen the result of messing with postgres memory
(the removed geomstats->histo[i] = something bug)
--strk;
