[postgis-devel] Re: [postgis-users] LWGEOM -- initial lwgeom.hfile
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Mar 5 04:55:25 PST 2004
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of David Blasby
> Sent: 05 March 2004 00:55
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Re: [postgis-users] LWGEOM --
> I've added the current version of lwgeom.h to CVS (even though its
> currently under discussion).
> I was also going to add these files:
> lwgeom_api.c   -- basic implementation of data access (ie. whats
> currently in lwgeom.h)
> lwgeom_inout.c -- reading/writing WKB and WKT. pg_dump
> representation...
> lwgeom_gist.c  -- functions required for indexing
> lwgeom_geos.c  -- for GEOS integration
> lwgeom_functions_basic.c -- simple OGC functions
> lwgeom_functions_analytic.c   -- more complex OGC functions
> lwgeom_transform.c  -- lat/long and PROJ4 functions
> lwgeom_estimate.c   -- planner functions
> Comments on organization?
> dave
Hi Dave,
I like the way that you are suggesting a distinction between OGC/non-OGC
functions - it can sometimes be hard to find the location of a
particular function if you don't know where you're looking. Also how
about putting all the LWGEOM stuff in a separate directory, just so that
when the existing code becomes obselete then we can guarantee that there
are no unexpected 'dependencies' between the two versions.
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
