[postgis-devel] tester output
strk
strk at keybit.net
Sat Mar 6 10:55:29 PST 2004
I forgot to tell:
MULTIPOLYGON statistics target was 10
POINT statistics target was 1000
Here are tests for POINT with statistics target 10
(3000 samples / 8000 rows)
[lo:test_outputs]$ grep avg strk-point-stat10-AOI
1 (best/worst/avg) 1 1 1
2 (best/worst/avg) 1 1.002 1
4 (best/worst/avg) 1 1.25 1.022
8 (best/worst/avg) 1 2 1.135
16 (best/worst/avg) 1 2 1.108
32 (best/worst/avg) 1 3 1.123
[lo:test_outputs]$ grep avg strk-point-stat10-noAOI 1 (best/worst/avg) 1 1 1
2 (best/worst/avg) 1 1.018 1.007
4 (best/worst/avg) 1.002 1.75 1.086
8 (best/worst/avg) 1.005 3 1.255
16 (best/worst/avg) 1.009 5 1.323
32 (best/worst/avg) 1.04 5 1.392
Here are tests for MULTIPOLYGON with statistics target 1000
(8000 samples / 8000 rows - the full set!)
[lo:test_outputs]$ grep avg strk-multipolygon-stat1000-noAOI 1 (best/worst/avg) 1 1 1
2 (best/worst/avg) 1.042 1.546 1.24
4 (best/worst/avg) 1.018 2.071 1.377
8 (best/worst/avg) 1 2.6 1.456
16 (best/worst/avg) 1 2.555 1.436
32 (best/worst/avg) -1.299 1.6 1.453
[lo:test_outputs]$ grep avg strk-multipolygon-stat1000-AOI 1 (best/worst/avg) 1 1 1
2 (best/worst/avg) 1.021 1.546 1.23
4 (best/worst/avg) -1.107 1.952 1.424
8 (best/worst/avg) -1.006 2.333 1.487
16 (best/worst/avg) 1 2 1.505
32 (best/worst/avg) -1.299 1 1.567
And here are the tests on MULTIPOLYGON run on PG74
(the full set - original implementation by David Blasby)
[lo:test_outputs]$ grep avg strk-multipolygon-PG74
2 (best/worst/avg) -1.037 1.145 1.065
4 (best/worst/avg) 1 1.14 1.119
8 (best/worst/avg) 1 2 1.176
16 (best/worst/avg) -1.151 3 1.318
32 (best/worst/avg) -1.083 3 1.566
--strk;
On Sat, Mar 06, 2004 at 07:19:28PM +0100, strk wrote:
> I've made some tests with ~ 8000 multipolgons and points
> (italian municipalities boundaries and their centroids)
> Here are the summaries of using the AOI/cell_area gain or
> not in the estimator.
> Histogram creator function acts the same for points and
> polygons (no AOI/cell_area is used at that phase)
> MULTIPOLYGON estm. gain = 1:
> 2 (best/worst/avg) -1.001 1.651 1.228
> 4 (best/worst/avg) -1.158 41 5.456
> 8 (best/worst/avg) -1.01 205 17.659
> 16 (best/worst/avg) -1.081 214 13.073
> 32 (best/worst/avg) 1 203 13.578
> MULTIPOLYGON estm. gain = AOI/cell_area:
> 2 (best/worst/avg) 1.006 1.125 1.05
> 4 (best/worst/avg) -1.164 4.6 1.493
> 8 (best/worst/avg) -1.284 32 3.599
> 16 (best/worst/avg) -1.085 26 2.461
> 32 (best/worst/avg) 1 18 2.18
> POINT estm. gain = 1:
> POINT estm. gain = AOI/cell_area:
> Could you do the same kind of test with your data ?
> Note that the tester now accept a list of comma separated
> bps values:
> test_estimator.pl table geom -bps 1,2,4,8,16,32
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
