[postgis-devel] postgis.sql.in
strk strk at keybit.net
Mon Mar 29 01:06:56 PST 2004
On Sat, Mar 27, 2004 at 01:00:34PM -0800, Paul Ramsey wrote:
> Definately tried it manually, which is how I found which commandline
> parameters were fussing it up. I have not tried an alternate shell yet,
> but I don't know exactly how that will help... if our build only works
> on bash, that is kind of a limiting...
> P
As an alternative we could keep using sed for keywords substitution
and cpp for conditional blocks. I'll try that and let you know.
--strk;
> On Friday, March 26, 2004, at 10:54 PM, strk wrote:
> > On Fri, Mar 26, 2004 at 12:59:10PM -0800, Paul Ramsey wrote:
> >> I still cannot use the cpp version in OS/X 10.2, unfortunately. The
> >> stdout fix helped one major problem, but the another problem remains.
> >> I
> >> simply cannot get the $libdir variable to go into the file, and I
> >> cannot
> >> get the '' marks to go into the file. cpp generally complains that it
> >> has the wrong number of arguments on the command line. I tried every
> >> combination I could think of... it was/is cpp 2.96.
> >> Paul
> > It works for me with:
> >  GNU CPP version 2.95.4 20011002 (Debian prerelease) (i386 Linux/ELF)
> > Did you try manually running it (without the intervention of make) ?
> > Also try changing the shell.
> > --strk;
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
>       Paul Ramsey
>       Refractions Research
>       Email: pramsey at refractions.net
>       Phone: (250) 885-0632
