[postgis-devel] postgis.sql.in
strk
strk at keybit.net
Mon Mar 29 22:54:09 PST 2004
On Mon, Mar 29, 2004 at 09:45:52AM -0800, Paul Ramsey wrote:
> That works :)
Good!
Should we set the new mechanism as the default
and get rid of all the _sql_ files ?
--strk;
> On Monday, March 29, 2004, at 02:44 AM, strk wrote:
> > I've modified postgis.sql.in and Makefile to use both sed for
> > keyworkds substitution and cpp for conditional blocks.
> > Can you try this version ?
> > --strk;
> > On Mon, Mar 29, 2004 at 11:06:56AM +0200, strk wrote:
> >> On Sat, Mar 27, 2004 at 01:00:34PM -0800, Paul Ramsey wrote:
> >>> Definately tried it manually, which is how I found which commandline
> >>> parameters were fussing it up. I have not tried an alternate shell
> >>> yet,
> >>> but I don't know exactly how that will help... if our build only
> >>> works
> >>> on bash, that is kind of a limiting...
> >>> P
> >> As an alternative we could keep using sed for keywords substitution
> >> and cpp for conditional blocks. I'll try that and let you know.
> >> --strk;
> >>> On Friday, March 26, 2004, at 10:54 PM, strk wrote:
> >>>> On Fri, Mar 26, 2004 at 12:59:10PM -0800, Paul Ramsey wrote:
> >>>>> I still cannot use the cpp version in OS/X 10.2, unfortunately. The
> >>>>> stdout fix helped one major problem, but the another problem
> >>>>> remains.
> >>>>> I
> >>>>> simply cannot get the $libdir variable to go into the file, and I
> >>>>> cannot
> >>>>> get the '' marks to go into the file. cpp generally complains that
> >>>>> it
> >>>>> has the wrong number of arguments on the command line. I tried
> >>>>> every
> >>>>> combination I could think of... it was/is cpp 2.96.
> >>>>> Paul
> >>>> It works for me with:
> >>>> GNU CPP version 2.95.4 20011002 (Debian prerelease) (i386
> >>>> Linux/ELF)
> >>>> Did you try manually running it (without the intervention of make) ?
> >>>> Also try changing the shell.
> >>>> --strk;
> >>>> _______________________________________________
> >>>> postgis-devel mailing list
> >>>> postgis-devel at postgis.refractions.net
> >>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> >>> Paul Ramsey
> >>> Refractions Research
> >>> Email: pramsey at refractions.net
> >>> Phone: (250) 885-0632
> Paul Ramsey
