[postgis-devel] simplify()
Kevin Neufeld
kneufeld at refractions.net
Mon Nov 22 08:54:56 PST 2004
Is this a bug with simplify(<geom>,<precision>)?
cwb_prod_11_10=# update valid_group_codes set the_geom =
simplify(the_geom, 1000) where group_code = 'BBAR';
UPDATE 1
simplify(the_geom, 1000) where group_code = 'LARL';
ERROR: out of memory
DETAIL: Failed on request of size 5441252.
For reference: the_geom in this case is a collection of linestrings,
making up a single multilinestring. Using a BC Albers projection and our
dataset, this query will simplify the_geom where every linestring in the
collection is composed of just its start and end points.
Kevin Neufeld,
Refractions Research Inc.,
Phone: (250) 383-3022
Fax: (250) 383-2140
