[postgis-devel] LWGEOM - XY,XYM,XYZ,XYZM
strk at refractions.net
Tue Oct 5 14:07:41 PDT 2004
News from the ZM front (still awake due to nightmare bugs!).
Four functions help you modifying dimensions of geometries:
force_2d(geom)
force_3dm(geom)
force_3dz(geom)
force_4d(geom)
The function do not change the semantic of the geometries,
rather they add or remove coordinate values.
Do you think a swapzm(geom) function would be useful ?
For example, I have a POINT(1 2 3) and want to change it
into a POINTM(1 2 3). Force_3dm would make it a POINTM(1 2 0).
force_3dm(swapzm(force_4d('POINT(1 2 3)'))) will do what I need:
force_4d --> 'POINT(1 2 3 0)'
swapzm --> 'POINT(1 2 0 3)'
force_3dm --> 'POINTM(1 2 3)'
What do you think ?
--strk;
On Tue, Oct 05, 2004 at 09:53:26AM +0200, strk at refractions.net wrote:
> Ok. The ZM flags are now handled as for internal representation.
> If you have 3d or 4d data already within LWGEOM you'll probably
> need a dump/restore. Internal storage size is the same, but two
> bits gets interpreted differently (old:DD, new:ZM)
> DD ZM
> 2d 00 00
> 3d 01 10|01
> 4d 10 11
> Old 3d geoms will be considered XYM.
> Old 4d geoms will be considered XYZ (and will be messed up in coordinates).
> The summary(geometry) function show all present flags for each geometry
> and subgeometry (ZMBS).
> Creation:
> WKT:
> Type(0 0) <=> TYPE
> Type(0 0 0) <=> TYPEZ
> Type(0 0 0 0) <=> TYPEZM
> TypeM(0 0 0) <=> TYPEM
> WKB:
> #define WKBZOFFSET 0x80000000
> #define WKBMOFFSET 0x40000000
> WARNING ! new WKB input is incompatible with previous version
> where 3D flag was current WKBZ and 4d flag was current WKBM
> This means that if you now use an OLD 4d WKB to create
> a NEW geometry it will be interpreted as TYPEM (3dimensions)
> thus corrupting the output.
> Questions ?
> --strk;
> On Mon, Oct 04, 2004 at 11:22:31AM +0200, strk at refractions.net wrote:
> > The adt work is on its way. We now have an LWGEOM abstract data type
> > with deserialize/serialize/clone/release functionalities.
> > The GEOS<->POSTGIS conversion has been fixed to keep geometry structure,
> > and the summary() function has a new format for better debugging.
> > Before going on with constructurs I think it's important to decide
> > what to do with hasM, hasZ flags.
> > My idea was to use two flags so to support:
> > XY - hasM=false hasZ=false
> > XYM - hasM=true hasZ=false
> > XYZ - hasM=false hasZ=true
> > XYZM - hasM=true hasZ=true
> > This would allow for space saving in the db and better semantic
> > specification.
> > In order to keep semantic in input/output WKT functions we might
> > add a <GEOM>M type as a custom extension:
> > POINT(1 2) <--> POINT
> > POINT(1 2 3) <--> POINTZ
> > POINT(1 2 3 4) <--> POINTZM
> > POINTM(1 2 4) <--> POINTM
> > Comments ?
> > --strk;
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
