[postgis-devel] urgent bug in LWGEOM WKB input/output
strk at refractions.net
Thu Oct 14 05:02:00 PDT 2004
I've found WKB input/output of LWGEOM to be bogus.
If I fully understood the problem Ralph Mason
parser/unparser uses the canonical HEXWKB form
which is sligtly larger then WKB.
This is for multitypes: a MultiPoint in canonical form has:
type: byte + MZ flags
npoints: 4bytes
POINT {
coords
The second 'type' (the one inside POINT) is useless.
This is true for both WKB and canonical form.
For WKB this is not only useless but also Malformed.
the lwgeom_inout.c contains the WKB output, which
basically invoke the HEXWKB output and transform it
from HEX to binary...
Did I introduce the bug or does it ring a bell for
Dave and Ralph ?
Note that I surely introduced a bug in the dumper because
I was initially convinced the WKB was good and the dumper
bogus...
--strk;
