[postgis-devel] bug in simplify a polygon
strk at refractions.net strk at refractions.net
Sat Sep 18 09:40:41 PDT 2004
My brain faulted trying to read the message...
can you provide a simpler example ?
--strk;
On Sat, Sep 18, 2004 at 12:48:36PM +0800, Fu Chen wrote:
> Hi!
> I find there must be some bugs in the function to simplify a polygon. some polygon get weird result after simplify.
> here is the example
> the source:
> SRID=-1;MULTIPOLYGON(((111.269523620605 30.0150585174561,111.288230895996 30.0127201080322,111.293571472168 29.9903964996338,111.316711425781 29.9730815887451,111.32396697998 29.9791641235352,111.337692260742 29.9541893005371,111.345428466797 29.9455871582031,111.371238708496 29.9550533294678,111.386726379395 29.9146823883057,111.40731048584 29.9150485992432,111.433601379395 29.9341297149658,111.444023132324 29.9282321929932,111.519607543945 29.9297733306885,111.53343963623 29.8999538421631,111.563743591309 29.8980693817139,111.693710327148 29.8899898529053,111.741439819336 29.920560836792,111.754547119141 29.9107666015625,111.791969299316 29.9089298248291,111.801872253418 29.894063949585,111.894577026367 29.8585758209229,111.930633544922 29.835620880127,111.954460144043 29.8392791748047,111.948577880859 29.807279586792,112.037857055664 29.7575340270996,112.060501098633 29.7476615905762,112.049507141113 29.7687644958496,112.05859375 29.7731666564941,112.072311401367 29.7440567016602,112.05859375 29.6876659393311,112.095657348633 29.6770248413086,112.126190185547 29.6595687866211,112.174980163574 29.662654876709,112.191352844238 29.629035949707,112.239288330078 29.664514541626,112.238906860352 29.6608505249023,112.235939025879 29.6184959411621,112.291580200195 29.5968437194824,112.297546386719 29.585470199585,112.290412902832 29.5500755310059,112.272499084473 29.5234069824219,112.282257080078 29.4988746643066,112.286163330078 29.510856628418,112.315818786621 29.5215167999268,112.322219848633 29.5462894439697,112.35986328125 29.5390071868896,112.380210876465 29.5506954193115,112.419738769531 29.6030006408691,112.42317199707 29.6281547546387,112.443138122559 29.6352577209473,112.485458374023 29.6335601806641,112.499603271484 29.6150970458984,112.530487060547 29.6026496887207,112.56413269043 29.6247692108154,112.601623535156 29.6128311157227,112.625671386719 29.6161327362061,112.640632629395 29.5918960571289,112.66227722168 29.6014461517334,112.678169250488 29.5969104766846,112.707290649414 29.6475639343262,112.750930786133 29.6608905792236,112.787750244141 29.696870803833,112.780326843262 29.717945098877,112.80005645752 29.7389945983887,112.849189758301 29.7804508209229,112.881530761719 29.7997760772705,112.894073486328 29.7966823577881,112.919242858887 29.7361240386963,112.917892456055 29.6977519989014,112.932083129883 29.6895618438721,112.989768981934 29.7477245330811,113.006698608398 29.7701950073242,113.02156829834 29.7729949951172,113.016059875488 29.7183132171631,112.991546630859 29.6883811950684,112.906036376953 29.6331367492676,112.912841796875 29.5917625427246,112.933242797852 29.4893417358398,112.95295715332 29.4716320037842,112.982238769531 29.4895648956299,113.00594329834 29.5023250579834,113.033493041992 29.512716293335,113.052421569824 29.5032367706299,113.062232971191 29.4873561859131,113.056587219238 29.4567737579346,113.066093444824 29.4372310638428,113.073387145996 29.4321422576904,113.08341217041 29.4321422576904,113.097991943359 29.4339656829834,113.115310668945 29.4385223388672,113.131721496582 29.443078994751,113.15926361084 29.4685096740723,113.213821411133 29.5446910858154,113.260787963867 29.5875816345215,113.31421661377 29.6429767608643,113.354042053223 29.6854953765869,113.41618347168 29.7476043701172,113.461242675781 29.7783241271973,113.489929199219 29.793363571167,113.518188476562 29.8250560760498,113.565139770508 29.8492603302002,113.57398223877 29.8340587615967,113.556182861328 29.8190250396729,113.54369354248 29.6824188232422,113.550193786621 29.6741790771484,113.595237731934 29.6714897155762,113.633338928223 29.6695652008057,113.659530639648 29.6840801239014,113.663726806641 29.6421794891357,113.697120666504 29.6353397369385,113.698303222656 29.6146469116211,113.714256286621 29.6125087738037,113.733467102051 29.5948905944824,113.730422973633 29.5798454284668,113.707733154297 29.5725708007812,113.701049804688 29.5585632324219,113.626197814941 29.5256881713867,113.631637573242 29.5117435455322,113.670547485352 29.5192527770996,113.734107971191 29.4703216552734,113.745040893555 29.4504451751709,113.732856750488 29.4074783325195,113.721076965332 29.3966255187988,113.657356262207 29.3813018798828,113.656707763672 29.3427639007568,113.625663757324 29.3171634674072,113.596641540527 29.2595901489258,113.631042480469 29.2543354034424,113.64208984375 29.2369899749756,113.688957214355 29.2352104187012,113.690467834473 29.2041778564453,113.653182983398 29.173282623291,113.649139404297 29.158727645874,113.682586669922 29.1209030151367,113.681121826172 29.0879020690918,113.719543457031 29.1095695495605,113.734230041504 29.0631771087646,113.766616821289 29.0962772369385,113.811347961426 29.1064605712891,113.82698059082 29.0988082885742,113.843612670898 29.0615158081055,113.872566223145 29.0708408355713,113.871589660645 29.0380535125732,113.900032043457 29.0361442565918,113.940132141113 29.0482807159424,113.955017089844 29.0029964447021,113.958023071289 28.9496459960938,113.970832824707 28.9439105987549,114.000717163086 28.9569263458252,114.018577575684 28.9056491851807,114.058410644531 28.8976821899414,114.051918029785 28.8687705993652,114.064277648926 28.8444385528564,114.083106994629 28.8382320404053,114.116333007812 28.8428592681885,114.139511108398 28.832670211792,114.145401000977 28.8179664611816,114.13111114502 28.7878665924072,114.145690917969 28.7714080810547,114.13786315918 28.7140064239502,114.121810913086 28.6886615753174,114.122627258301 28.6077098846436,114.077743530273 28.5583877563477,114.088317871094 28.5436267852783,114.122993469238 28.5370674133301,114.148277282715 28.5076866149902,114.208030700684 28.48708152771,114.207496643066 28.4698581695557,114.169921875 28.4375686645508,114.195037841797 28.4285907745361,114.217483520508 28.4036865234375,114.249946594238 28.3983936309814,114.253929138184 28.3849983215332,114.247627258301 28.3274345397949,114.198143005371 28.2954292297363,114.174766540527 28.2604312896729,114.139152526855 28.2499923706055,114.089996337891 28.1890563964844,114.034362792969 28.1803894042969,113.999847412109 28.1889972686768,113.987747192383 28.1772613525391,113.991226196289 28.1518955230713,114.009437561035 28.1358966827393,114.016700744629 28.1079502105713,114.03450012207 28.0874977111816,114.034713745117 28.0661754608154,114.02335357666 28.0485572814941,113.999839782715 28.0543098449707,113.953483581543 28.0433368682861,113.95565032959 28.0230674743652,113.925941467285 28.0195369720459,113.918327331543 28.0004444122314,113.871063232422 27.9946804046631,113.860618591309 28.013578414917,113.853019714355 28.0117778778076,113.84049987793 27.9820384979248,113.800048828125 27.9800872802734,113.767189025879 27.9541530609131,113.727172851562 27.8895225524902,113.731292724609 27.8738594055176,113.753776550293 27.8586368560791,113.76171875 27.8114776611328,113.695922851562 27.748104095459,113.690811157227 27.7222347259521,113.646682739258 27.6670398712158,113.606117248535 27.6365737915039,113.596290588379 27.5894145965576,113.573402404785 27.5486145019531,113.57795715332 27.5281257629395,113.621841430664 27.5135669708252,113.60376739502 27.4825782775879,113.586303710938 27.4710922241211,113.592346191406 27.4322204589844,113.602546691895 27.4242191314697,113.625526428223 27.413200378418,113.597290039062 27.3892269134521,113.611289978027 27.3488731384277,113.639213562012 27.3537940979004,113.67391204834 27.3349723815918,113.694267272949 27.335391998291,113.717247009277 27.3523025512695,113.735252380371 27.350679397583,113.757400512695 27.3641510009766,113.820869445801 27.3683128356934,113.867378234863 27.3883056640625,113.867683410645 27.350191116333,113.84937286377 27.3086719512939,113.867362976074 27.2934875488281,113.847770690918 27.238208770752,113.769561767578 27.1280536651611,113.769706726074 27.0942058563232,113.782737731934 27.0898914337158,113.802230834961 27.1010990142822,113.81551361084 27.0412101745605,113.837760925293 27.0358409881592,113.84285736084 27.0201530456543,113.861099243164 27.0198879241943,113.866249084473 26.9936370849609,113.887336730957 26.968297958374,113.916236877441 26.9621295928955,113.922889709473 26.9480228424072,113.902847290039 26.9340839385986,113.883117675781 26.8693904876709,113.834739685059 26.8074035644531,113.847450256348 26.7746105194092,113.857521057129 26.7512702941895,113.863166809082 26.6572589874268,113.906478881836 26.6189575195312,113.93505859375 26.6139354705811,113.97541809082 26.622278213501,113.995506286621 26.615535736084,114.028022766113 26.5853443145752,114.099769592285 26.5805015563965,114.069580078125 26.4964218139648,114.075416564941 26.4846038818359,114.0947265625 26.4796352386475,114.078712463379 26.4517250061035,114.081886291504 26.4149475097656,114.055488586426 26.4106464385986,114.028541564941 26.384090423584,114.017723083496 26.347583770752,114.031173706055 26.3129024505615,113.995780944824 26.2478256225586,113.965072631836 26.2439384460449,113.963500976562 26.2030773162842,113.940567016602 26.1914844512939,113.944580078125 26.1751155853271,113.93628692627 26.1688098907471,113.955383300781 26.1535892486572,113.968147277832 26.1545429229736,114.000541687012 26.1842136383057,114.035133361816 26.1914310455322,114.058563232422 26.1696319580078,114.07861328125 26.1660232543945,114.101402282715 26.1910457611084,114.167686462402 26.2122039794922,114.179908752441 26.2011680603027,114.205947875977 26.2024707794189,114.218383789062 26.1900501251221,114.213310241699 26.1715660095215,114.227897644043 26.154052734375,114.194641113281 26.1288070678711,114.102561950684 26.103588104248,114.11255645752 26.0859470367432,114.093360900879 26.0714130401611,114.040008544922 26.0763626098633,114.005126953125 26.012321472168,114.018562316895 25.988655090332,114.015258789062 25.9781627655029,114.02571105957 25.9260940551758,114.016677856445 25.8991889953613,113.96460723877 25.8346347808838,113.95304107666 25.7764701843262,113.914642333984 25.7363986968994,113.912063598633 25.7079544067383,113.944580078125 25.6167297363281,113.971771240234 25.6052856445312,113.985626220703 25.5621166229248,113.977127075195 25.5296306610107,113.955978393555 25.5251350402832,113.937362670898 25.4808597564697,113.957168579102 25.4692993164062,113.959213256836 25.4573230743408,113.934707641602 25.4358787536621,113.883773803711 25.4364166259766,113.877632141113 25.3937835693359,113.865646362305 25.3767356872559,113.832443237305 25.3613739013672,113.82568359375 25.3385009765625,113.812072753906 25.3281326293945,113.762168884277 25.3281555175781,113.7548828125 25.3592662811279,113.745323181152 25.3630752563477,113.726806640625 25.3484020233154,113.714820861816 25.3575248718262,113.682250976562 25.3494701385498,113.671043395996 25.3305568695068,113.639686584473 25.3339614868164,113.61792755127 25.3202362060547,113.573753356934 25.3134574890137,113.568489074707 25.3191299438477,113.57649230957 25.3414421081543,113.534843444824 25.3658580780029,113.516876220703 25.3511505126953,113.501022338867 25.3740844726562,113.467323303223 25.3731155395508,113.438262939453 25.3617458343506,113.412643432617 25.3928260803223,113.391746520996 25.4024848937988,113.364608764648 25.4007263183594,113.350982666016 25.4392356872559,113.317481994629 25.4549961090088,113.30216217041 25.4471244812012,113.308242797852 25.4824295043945,113.292999267578 25.4989032745361,113.294036865234 25.5186443328857,113.284629821777 25.5171375274658,113.275756835938 25.4995460510254,113.227279663086 25.5152149200439,113.189323425293 25.4836769104004,113.154136657715 25.4879322052002,113.123542785645 25.4546947479248,113.122749328613 25.4122142791748,113.095191955566 25.4172992706299,113.079299926758 25.3823070526123,113.041168212891 25.3711738586426,113.015060424805 25.3484382629395,112.979911804199 25.3537998199463,112.961029052734 25.3408718109131,112.939483642578 25.3392143249512,112.920356750488 25.3040027618408,112.896583557129 25.3062629699707,112.885528564453 25.338737487793,112.866638183594 25.3246459960938,112.852760314941 25.3293476104736,112.862548828125 25.2477378845215,112.895347595215 25.2385196685791,112.973983764648 25.2544021606445,113.023803710938 25.2089500427246,113.02562713623 25.1921672821045,112.981170654297 25.1751022338867,112.960227966309 25.1571388244629,112.96378326416 25.1359786987305,113.008903503418 25.0795478820801,112.997009277344 25.0566864013672,112.972396850586 25.0479431152344,112.968696594238 25.0341930389404,112.98014831543 25.0187072753906,112.977416992188 25.0001277923584,113.002326965332 24.9923324584961,113.003257751465 24.963846206665,113.001892089844 24.9326229095459,112.988128662109 24.9212608337402,112.890953063965 24.919548034668,112.855377197266 24.8968639373779,112.773948669434 24.8969707489014,112.77530670166 24.9411010742188,112.737396240234 24.9620399475098,112.735229492188 25.0006370544434,112.697937011719 25.0105381011963,112.700698852539 25.0362396240234,112.717346191406 25.0604724884033,112.686836242676 25.0974235534668,112.665176391602 25.1062927246094,112.651000976562 25.1316471099854,112.535423278809 25.1270523071289,112.481750488281 25.1514549255371,112.456199645996 25.1497459411621,112.438980102539 25.182445526123,112.413963317871 25.147424697876,112.397987365723 25.141529083252,112.385643005371 25.1470966339111,112.356338500977 25.192699432373,112.306137084961 25.1733837127686,112.290367126465 25.156909942627,112.272468566895 25.1663932800293,112.247146606445 25.1621227264404,112.199806213379 25.2020149230957,112.180763244629 25.1839294433594,112.155471801758 25.0733089447021,112.141242980957 25.0533695220947,112.144882202148 25.0195999145508,112.112930297852 24.989372253418,112.10880279541 24.9668769836426,112.160133361816 24.9293003082275,112.167053222656 24.9156494140625,112.149291992188 24.8154258728027,112.13591003418 24.8108692169189,112.118103027344 24.8350315093994,112.09765625 24.8318691253662,112.077133178711 24.8034420013428,112.02961730957 24.7709369659424,112.015907287598 24.7399616241455,111.955772399902 24.7706089019775,111.933067321777 24.7600784301758,111.898551940918 24.7665500640869,111.867790222168 24.7587738037109,111.86353302002 24.7748527526855,111.843383789062 24.7790012359619,111.803039550781 24.7739734649658,111.769287109375 24.7896003723145,111.731460571289 24.7755947113037,111.700210571289 24.7856941223145,111.676261901855 24.7774200439453,111.637191772461 24.7330760955811,111.633911132812 24.6839294433594,111.588569641113 24.6960601806641,111.561393737793 24.6411457061768,111.543769836426 24.6459445953369,111.519859313965 24.6341991424561,111.512046813965 24.6392383575439,111.492637634277 24.6642379760742,111.464179992676 24.6648750305176,111.432441711426 24.6710090637207,111.422592163086 24.686372756958,111.44896697998 24.7270755767822,111.474082946777 24.8003826141357,111.443977355957 24.8598022460938,111.456062316895 24.8804950714111,111.44165802002 24.8958530426025,111.463081359863 24.9163341522217,111.464820861816 24.9317245483398,111.434761047363 24.9472808837891,111.42537689209 24.9697666168213,111.432929992676 24.9870071411133,111.459426879883 24.9985446929932,111.459892272949 25.0265617370605,111.433868408203 25.0301837921143,111.412879943848 25.0441474914551,111.413352966309 25.0682621002197,111.431228637695 25.1011428833008,111.402397155762 25.1056709289551,111.389717102051 25.1311340332031,111.369743347168 25.1313133239746,111.35717010498 25.1041793823242,111.338226318359 25.0972385406494,111.30103302002 25.1115989685059,111.275917053223 25.1418361663818,111.263023376465 25.1456966400146,111.180130004883 25.0670833587646,111.15210723877 25.0591640472412,111.136260986328 25.0423336029053,111.093872070312 25.0313549041748,111.097312927246 24.9976100921631,111.08570098877 24.940372467041,110.991653442383 24.9226894378662,110.979843139648 24.9591426849365,110.952339172363 25.0005626678467,110.942008972168 25.0409259796143,110.951637268066 25.0777244567871,110.971519470215 25.0945987701416,110.971893310547 25.1198616027832,110.992393493652 25.1606216430664,111.060043334961 25.1882877349854,111.098861694336 25.2164859771729,111.104362487793 25.2305183410645,111.091987609863 25.2819080352783,111.134910583496 25.3075885772705,111.171173095703 25.3587226867676,111.200546264648 25.3602142333984,111.230888366699 25.3791561126709,111.255851745605 25.4166774749756,111.291236877441 25.4443511962891,111.296981811523 25.4783611297607,111.322212219238 25.5262069702148,111.310966491699 25.5597057342529,111.333938598633 25.606164932251,111.303886413574 25.6416759490967,111.30859375 25.6855564117432,111.301452636719 25.6986255645752,111.297607421875 25.7105560302734,111.311782836914 25.7305793762207,111.382400512695 25.7365131378174,111.410552978516 25.7710304260254,111.434692382812 25.7724609375,111.419578552246 25.836275100708,111.451377868652 25.8510208129883,111.482620239258 25.8600559234619,111.484382629395 25.8738403320312,111.44953918457 25.8698692321777,111.447219848633 25.8896160125732,111.427131652832 25.8808460235596,111.402946472168 25.8860740661621,111.377258300781 25.8844051361084,111.363998413086 25.900447845459,111.325057983398 25.901948928833,111.292549133301 25.8816413879395,111.287010192871 25.859806060791,111.27660369873 25.8547210693359,111.245536804199 25.8633460998535,111.215400695801 25.8979187011719,111.217109680176 25.9190540313721,111.193313598633 25.955940246582,111.19522857666 25.9869537353516,111.212623596191 26.0386924743652,111.247970581055 26.0576477050781,111.243797302246 26.0840435028076,111.266876220703 26.1213264465332,111.248443603516 26.1492824554443,111.265426635742 26.1775856018066,111.25715637207 26.212007522583,111.282119750977 26.2277050018311,111.281776428223 26.2548007965088,111.259803771973 26.2669010162354,111.197769165039 26.2689800262451,111.189010620117 26.289155960083,111.161117553711 26.3067321777344,111.092948913574 26.3057537078857,111.069892883301 26.3233337402344,111.038757324219 26.3174438476562,111.014686584473 26.3304176330566,110.99250793457 26.3236446380615,110.989250183105 26.3585338592529,110.977096557617 26.3846492767334,110.958686828613 26.3863906860352,110.937812805176 26.3759422302246,110.941596984863 26.338529586792,110.922813415527 26.3193645477295,110.932929992676 26.2923221588135,110.915008544922 26.2589225769043,110.893707275391 26.2767124176025,110.850860595703 26.2716331481934,110.831787109375 26.2595729827881,110.783798217773 26.261791229248,110.756553649902 26.2524223327637,110.727561950684 26.2726631164551,110.745506286621 26.2971305847168,110.736923217773 26.3172817230225,110.706199645996 26.2952480316162,110.676651000977 26.3186893463135,110.630470275879 26.3139801025391,110.612648010254 26.337495803833,110.581008911133 26.3048667907715,110.570121765137 26.2664260864258,110.537712097168 26.2657012939453,110.540817260742 26.2324275970459,110.512901306152 26.1901664733887,110.485809326172 26.1688041687012,110.469352722168 26.1833591461182,110.433143615723 26.1570873260498,110.368553161621 26.0921821594238,110.320861816406 25.9787254333496,110.276931762695 25.968412399292,110.243583679199 25.9682998657227,110.240623474121 26.0254573822021,110.207496643066 26.0462417602539,110.191909790039 26.0713405609131,110.176971435547 26.0635986328125,110.150749206543 26.021053314209,110.110527038574 26.0380630493164,110.093147277832 26.0224761962891,110.06014251709 26.0531044006348,110.070137023926 26.1069641113281,110.087059020996 26.1381645202637,110.081283569336 26.1711692810059,110.046829223633 26.1723804473877,110.022773742676 26.1594638824463,110.003799438477 26.1851902008057,109.979850769043 26.1832962036133,109.961769104004 26.1989212036133,109.902809143066 26.1483459472656,109.895599365234 26.1011714935303,109.881286621094 26.0867481231689,109.864486694336 26.0341644287109,109.835716247559 26.0324096679688,109.810066223145 26.0442447662354,109.797416687012 26.0376434326172,109.777709960938 25.9953441619873,109.801933288574 25.9768371582031,109.821472167969 25.914623260498,109.801666259766 25.8780689239502,109.774597167969 25.8689746856689,109.757362365723 25.8809146881104,109.742416381836 25.892650604248,109.657066345215 25.883638381958,109.68586730957 25.9577789306641,109.706611633301 25.9663410186768,109.717987060547 25.9874019622803,109.700042724609 26.0105781555176,109.647438049316 26.0178680419922,109.636222839355 26.048942565918,109.614883422852 26.0454139709473,109.593803405762 26.0260391235352,109.546737670898 26.022346496582,109.524223327637 25.9990348815918,109.508651733398 26.0013236999512,109.478019714355 26.0327739715576,109.463386535645 26.0807800292969,109.500381469727 26.1066226959229,109.505477905273 26.1209411621094,109.495079040527 26.146276473999,109.466567993164 26.1575469970703,109.463722229004 26.1735801696777,109.443496704102 26.1909465789795,109.465797424316 26.1995658874512,109.447692871094 26.212833404541,109.434898376465 26.2420291900635,109.451683044434 26.2702732086182,109.452583312988 26.2792892456055,109.476058959961 26.2943572998047,109.45881652832 26.3149871826172,109.443817138672 26.3115367889404,109.446022033691 26.2890625,109.424476623535 26.2944622039795,109.364738464355 26.280403137207,109.337379455566 26.2562961578369,109.333778381348 26.2709350585938,109.284278869629 26.2949104309082,109.267860412598 26.3371238708496,109.290298461914 26.3519744873047,109.322212219238 26.4312915802002,109.376152038574 26.4579029083252,109.35765838623 26.4755153656006,109.380783081055 26.4967937469482,109.376983642578 26.521764755249,109.399543762207 26.5329246520996,109.403053283691 26.549976348877,109.395812988281 26.5673141479492,109.37467956543 26.5747814178467,109.373962402344 26.6257553100586,109.356239318848 26.6415424346924,109.352027893066 26.6607646942139,109.329452514648 26.6495990753174,109.306427001953 26.6611576080322,109.28247833252 26.6931381225586,109.284553527832 26.7046546936035,109.357200622559 26.6978244781494,109.381210327148 26.7154388427734,109.376556396484 26.7307529449463,109.407699584961 26.7239055633545,109.412971496582 26.743049621582,109.449226379395 26.7645244598389,109.493087768555 26.763599395752,109.500030517578 26.7480907440186,109.50740814209 26.7511901855469,109.512977600098 26.7834243774414,109.491996765137 26.8228321075439,109.50855255127 26.8437538146973,109.509216308594 26.8777503967285,109.488830566406 26.8843250274658,109.477241516113 26.9004516601562,109.445182800293 26.8717041015625,109.431823730469 26.8868789672852,109.497253417969 26.92946434021,109.525718688965 26.9310474395752,109.55020904541 26.9541492462158,109.541511535645 26.9811153411865,109.525032043457 26.9833927154541,109.534446716309 27.0028247833252,109.51513671875 27.0337600708008,109.507171630859 27.0761165618896,109.496597290039 27.0782508850098,109.469932556152 27.0603885650635,109.457206726074 27.0673084259033,109.45435333252 27.0831069946289,109.467987060547 27.1381969451904,109.452842712402 27.1365852355957,109.436149597168 27.1213970184326,109.399879455566 27.1628398895264,109.276016235352 27.1304950714111,109.263122558594 27.1323432922363,109.243598937988 27.156810760498,109.191390991211 27.0945987701416,109.159156799316 27.0745162963867,109.10001373291 27.0759830474854,109.103630065918 27.0985527038574,109.128898620605 27.119213104248,109.126441955566 27.1260585784912,109.082412719727 27.1169986724854,109.016822814941 27.0942039489746,108.948341369629 27.0536441802979,108.933990478516 27.0180034637451,108.902847290039 27.0203876495361,108.867858886719 27.0004119873047,108.833358764648 27.0573711395264,108.796653747559 27.0770740509033,108.783111572266 27.0836887359619,108.792083740234 27.0955829620361,108.826026916504 27.0948867797852,108.851043701172 27.1142120361328,108.876007080078 27.1126365661621,108.881309509277 27.1278972625732,108.914863586426 27.1673564910889,108.89705657959 27.2133960723877,109.053146362305 27.2895946502686,109.045829772949 27.3408908843994,109.086486816406 27.3432426452637,109.104682922363 27.3596420288086,109.112640380859 27.3969802856445,109.130271911621 27.4163513183594,109.125419616699 27.4380741119385,109.142463684082 27.4493980407715,109.154457092285 27.4429531097412,109.15160369873 27.419713973999,109.203216552734 27.4536762237549,109.236610412598 27.4351959228516,109.241020202637 27.4214954376221,109.289642333984 27.4266796112061,109.302307128906 27.4376811981201,109.301902770996 27.4840488433838,109.383293151855 27.5443782806396,109.404510498047 27.5548191070557,109.428833007812 27.5515327453613,109.449760437012 27.5777988433838,109.462699890137 27.6319465637207,109.445129394531 27.6872234344482,109.423477172852 27.7114429473877,109.432693481445 27.7437229156494,109.377227783203 27.73779296875,109.342147827148 27.7732601165771,109.311920166016 27.7847003936768,109.32576751709 27.8039798736572,109.320587158203 27.8172054290771,109.331588745117 27.8366661071777,109.322143554688 27.8695621490479,109.30786895752 27.8842449188232,109.318008422852 27.908052444458,109.306533813477 27.9250755310059,109.301528930664 27.9681396484375,109.320587158203 28.0009441375732,109.373123168945 28.0326595306396,109.360458374023 28.0544414520264,109.339233398438 28.064302444458,109.314086914062 28.0443515777588,109.296478271484 28.0468673706055,109.299346923828 28.0764465332031,109.339332580566 28.1569290161133,109.337020874023 28.1816921234131,109.358123779297 28.2493324279785,109.378387451172 28.2727146148682,109.369049072266 28.2766151428223,109.348793029785 28.2646942138672,109.343383789062 28.2963371276855,109.294822692871 28.2793598175049,109.267463684082 28.3193302154541,109.267311096191 28.3286571502686,109.266563415527 28.3391628265381,109.271057128906 28.3459148406982,109.277816772461 28.351167678833,109.282318115234 28.3564205169678,109.284568786621 28.3624229431152,109.283821105957 28.3654232025146,109.277061462402 28.3699264526367,109.271812438965 28.3736782073975,109.271057128906 28.3766784667969,109.269561767578 28.3804302215576,109.262046813965 28.3841819763184,109.258308410645 28.3924369812012,109.256057739258 28.4021911621094,109.254547119141 28.4089431762695,109.254257202148 28.4266185760498,109.254547119141 28.4374561309814,109.254547119141 28.4487113952637,109.255302429199 28.4607162475586,109.258308410645 28.4682197570801,109.264312744141 28.4727230072021,109.268058776855 28.4802265167236,109.271057128906 28.4869785308838,109.271057128906 28.4929809570312,109.269897460938 28.502290725708,109.273361206055 28.5088157653809,109.273826599121 28.5162162780762,109.272903442383 28.5226917266846,109.271049499512 28.5277805328369,109.271049499512 28.5314807891846,109.274063110352 28.5342502593994,109.278450012207 28.5365695953369,109.283073425293 28.5407314300537,109.285850524902 28.5490570068359,109.288627624512 28.555534362793,109.291320800781 28.5627632141113,109.297416687012 28.5689468383789,109.304817199707 28.5721855163574,109.312683105469 28.5731105804443,109.315826416016 28.5936603546143,109.286422729492 28.6204795837402,109.247093200684 28.6076126098633,109.22469329834 28.6144714355469,109.19603729248 28.6025142669678,109.179626464844 28.623592376709,109.212181091309 28.6483974456787,109.26481628418 28.6688556671143,109.24919128418 28.694299697876,109.290649414062 28.7161121368408,109.299751281738 28.7368640899658,109.28515625 28.7542839050293,109.255958557129 28.7636661529541,109.255836486816 28.7663707733154,109.244247436523 28.7711219787598,109.237716674805 28.7800598144531,109.243209838867 28.8114814758301,109.231986999512 28.8788967132568,109.253677368164 28.9539089202881,109.286109924316 28.9860382080078,109.291358947754 29.0195236206055,109.315696716309 29.0472831726074,109.300277709961 29.0649375915527,109.224670410156 29.0935535430908,109.22859954834 29.1224555969238,109.24144744873 29.1156597137451,109.251922607422 29.1216278076172,109.257431030273 29.1665840148926,109.268692016602 29.1732406616211,109.268707275391 29.2032852172852,109.253776550293 29.2268981933594,109.338722229004 29.2702732086182,109.340141296387 29.3679733276367,109.378929138184 29.3855152130127,109.373329162598 29.3962497711182,109.364463806152 29.4065170288086,109.367263793945 29.420051574707,109.372863769531 29.426118850708,109.379386901855 29.4312534332275,109.38452911377 29.4340534210205,109.390586853027 29.4335880279541,109.401329040527 29.429386138916,109.402732849121 29.4335880279541,109.400863647461 29.4368553161621,109.399932861328 29.441987991333,109.404586791992 29.4443225860596,109.4111328125 29.4443225860596,109.413467407227 29.4461898803711,109.407402038574 29.454122543335,109.403663635254 29.460657119751,109.400459289551 29.4681186676025,109.406929016113 29.474193572998,109.40926361084 29.479793548584,109.40926361084 29.4933280944824,109.414863586426 29.4947280883789,109.419998168945 29.4937953948975,109.426536560059 29.4900608062744,109.431198120117 29.4849281311035,109.43586730957 29.4844608306885,109.436813354492 29.4877281188965,109.436332702637 29.4909954071045,109.432601928711 29.4979953765869,109.430732727051 29.502197265625,109.430267333984 29.5045299530029,109.427001953125 29.5110645294189,109.425598144531 29.5171318054199,109.426536560059 29.5231990814209,109.427932739258 29.5255336761475,109.430732727051 29.5264663696289,109.437271118164 29.5250663757324,109.441467285156 29.520866394043,109.446136474609 29.514331817627,109.451736450195 29.5101299285889,109.457336425781 29.5091972351074,109.460136413574 29.5119972229004,109.458740234375 29.520866394043,109.456871032715 29.5241317749023,109.456413269043 29.5297336578369,109.456871032715 29.5395355224609,109.457801818848 29.5470027923584,109.462013244629 29.5549373626709,109.491012573242 29.5699462890625,109.498466491699 29.6086959838867,109.510047912598 29.6066188812256,109.514556884766 29.6217498779297,109.560028076172 29.6109046936035,109.576400756836 29.6299095153809,109.602210998535 29.6369724273682,109.645317077637 29.6267910003662,109.656768798828 29.5992431640625,109.702590942383 29.6110496520996,109.714706420898 29.6165218353271,109.707527160645 29.6557579040527,109.693916320801 29.6702442169189,109.759826660156 29.6920680999756,109.764617919922 29.749849319458,109.787086486816 29.7660598754883,109.865142822266 29.7774696350098,109.903266906738 29.7669925689697,109.942863464355 29.7762222290039,110.019233703613 29.7721824645996,110.108451843262 29.7921047210693,110.155807495117 29.7562713623047,110.194259643555 29.7555713653564,110.240936279297 29.7348480224609,110.285057067871 29.6989898681641,110.294982910156 29.6649742126465,110.342239379883 29.6682510375977,110.35090637207 29.6445636749268,110.368431091309 29.6345691680908,110.436157226562 29.6649856567383,110.462013244629 29.7115516662598,110.515632629395 29.6946105957031,110.63321685791 29.7636947631836,110.630523681641 29.7958297729492,110.608932495117 29.8359470367432,110.586486816406 29.8331775665283,110.542022705078 29.8592796325684,110.528800964355 29.8974723815918,110.50106048584 29.9149208068848,110.504089355469 29.9458560943604,110.549293518066 29.9913196563721,110.49292755127 30.0232448577881,110.522758483887 30.062427520752,110.605690002441 30.0598258972168,110.646141052246 30.0803031921387,110.685333251953 30.066837310791,110.704467773438 30.0393486022949,110.735733032227 30.0447559356689,110.751441955566 30.0533027648926,110.758682250977 30.0773086547852,110.742340087891 30.1148662567139,110.762046813965 30.1247463226318,110.804496765137 30.1167144775391,110.820266723633 30.1280059814453,110.91813659668 30.1144886016846,110.923683166504 30.0674057006836,111.24471282959 30.0433864593506,111.269523620605 30.0150585174561),(109.537452697754 26.7500324249268,109.538078308105 26.7270469665527,109.558242797852 26.7242679595947,109.580940246582 26.7345542907715,109.585716247559 26.7597694396973,109.571006774902 26.7673091888428,109.537452697754 26.7500324249268)))
> after simplify(the_geom,0.01) the result is:
> SRID=-1;MULTIPOLYGON(((-2.68151938993771e+154 -2.68159547427887e+154,2.68155263531108e+154 -1.49166334607772e-154,-2.68156670066134e+154 -1.49167277157142e-154,-1.99998760223389 -1.999997378732,2.68155263531108e+154 2.68158013026139e+154,1.49171509090483e-154 -1.49168272953112e-154,2.68158971668906e+154 -1.49168272953123e-154,-2.68154240596543e+154 -1.49168272953143e-154,1.99997901916504 -1.49167846183504e-154,-2.68151938993771e+154 2.68157245825373e+154,2.68163574874448e+154 -2.68158524493609e+154,-1.99997043609619 2.68158013026453e+154,-2.00000762939453 -2.68156734358294e+154,-5.51718905650971e-313 5.33475836536549e-315,-2.68156670066134e+154 2.68159035961124e+154,-1.99998760223389 -1.49168841979627e-154,-1.90979621186875e-313 2.00002527504643,-2.68156670066134e+154 9.02146061846263e-314,1.99999618530273 -1.99999737873454,1.49165392058404e-154 -1.99999737873459,0 1.99998974934009,-1.99998760223389 -2.59974279002256e-313,0 -2.68159547428657e+154,2.00002479553223 -4.77747017979999e-314,-2.68154240596543e+154 -2.00000810891051,-1.49167810419924e-154 -1.99999737873526,1.99997901916504 -1.99999451771252,3.81959242373749e-313 2.68159035961607e+154,-1.49170228781443e-154 1.53874505659345e-313,2.68155263531108e+154 1.49168557466736e-154,2.00002479553223 -1.49166334608052e-154,0 2.68154400609744e+154,2.68158971668906e+154 2.68155295677499e+154,1.99997901916504 -2.00001573830685,2.68163574874448e+154 2.00001955300426,-1.99997043609619 2.38754354535907e-313,-1.90979621186875e-313 1.99999928608497,-2.00004196166992 -2.68155167810768e+154,3.81959242373749e-313 -2.6815954742921e+154,-2.00004196166992 2.68156222891909e+154,1.49165392058404e-154 1.49167988440693e-154,1.99999618530273 -2.00001573830892,2.00002479553223 1.49166192351609e-154,-5.51718905650971e-313 1.49166690249578e-154,-2.68161273271677e+154 2.00002527505261,1.49171509090483e-154 -2.00001573830959,3.81959242373749e-313 1.49166690249604e-154,-2.68161273271677e+154 -1.49167277158024e-154,-2.00004196166992 -2.6815852449493e+154,2.00002479553223 1.49167988440831e-154,2.68163574874448e+154 -2.68159547429565e+154,2.68158971668906e+154 9.02146925670638e-314,1.49165392058404e-154 2.6815724582682e+154,0 -1.99999737873773,1.99997901916504 -2.6815775729404e+154,2.68158971668906e+154 2.68156222892245e+154,-1.99998760223389 2.68159035962325e+154,-2.68154240596543e+154 1.49167561671216e-154,-1.49164751903885e-154 2.68157245826865e+154,1.49165392058404e-154 1.49167988440898e-154,-2.68154240596543e+154 2.68158013027792e+154,2.68155263531108e+154 -2.68155167811016e+154,-1.49166032212924e-154 -2.68155167811021e+154,1.99997901916504 9.02147001559121e-314,1.49166672367444e-154 -1.49167846184379e-154,2.68158971668906e+154 2.00001955300947,2.00002479553223 -2.68155167811085e+154,-1.99998760223389 -2.00000810891842,-1.49170228781443e-154 -1.49166547993172e-154,-2.00004196166992 9.02147245084078e-314,3.81959242373749e-313 -2.68156734359999e+154,2.00002479553223 1.49166992645254e-154,1.49171509090483e-154 -2.68157757294646e+154,-2.68151938993771e+154 9.02147348294391e-314,2.68163574874448e+154 -2.00001573831538,-1.49170228781443e-154 -1.49168272954331e-154,-1.99997043609619 -2.68158524495653e+154,-5.51718905650971e-313 -2.68154656344022e+154,-1.49167810419924e-154 -1.49167846184686e-154,2.68155263531108e+154 2.68155807145432e+154,2.00005912780762 -1.99999737874048,-2.00004196166992 2.68156222892966e+154,1.49166672367444e-154 1.99999261036909,-1.90979621186875e-313 2.6815491207766e+154,-2.68154240596543e+154 -1.49166334608406e-154,2.68153089795157e+154 -1.11434697027582e-313,3.81959242373749e-313 1.4916756167153e-154,0 2.6815724582743e+154,-2.68151938993771e+154 -2.00001573831606,-1.99997043609619 1.9999964250661,-1.90979621186875e-313 2.68155295678118e+154,-1.90979621186875e-313 -2.00000238687558,-1.49167810419924e-154 2.68154400610415e+154,1.99999618530273 -1.49167846184724e-154,-1.99997043609619 -1.96314548656089e-313,1.49171509090483e-154 -1.49167277158541e-154,1.49171509090483e-154 -2.68154656344123e+154,3.81959242373749e-313 2.68154400610523e+154,1.99999618530273 3.02414347468083e-313,-2.00000762939453 1.49166992645491e-154,2.68163574874448e+154 -1.4916827295454e-154,-1.49166032212924e-154 -1.99999070302166,-1.49167810419924e-154 2.68158013028784e+154,-1.99997043609619 -2.68156734360633e+154,2.00005912780762 1.99998974934768,3.81959242373749e-313 9.02147835640745e-314,-2.00004196166992 1.49166992645565e-154,1.49168948472404e-154 -2.6815954743067e+154,-1.99997043609619 -2.59974441337405e-313,3.81959242373749e-313 1.49166405736811e-154,1.49165392058404e-154 2.00001192362195,2.68158971668906e+154 -1.99999070302201,2.68163574874448e+154 2.68159035963471e+154,1.49165392058404e-154 1.49165907838895e-154,2.68163574874448e+154 1.99999928609124,1.49168948472404e-154 -1.99999451771963,2.68155263531108e+154 1.99999261037082,2.68153089795157e+154 -1.49168841980865e-154,-2.68151938993771e+154 -1.96314572578747e-313,-5.51718905650971e-313 1.53874652782213e-313,2.00002479553223 2.38754476145225e-313,-1.49167810419924e-154 -1.49167277158619e-154,1.99997901916504 1.99998974934728,-1.99998760223389 -2.68155167811485e+154,-1.49166032212924e-154 1.99998974934724,2.68158971668906e+154 1.99999928609031,-2.68156670066134e+154 1.49166192351935e-154,2.68158971668906e+154 -1.99999070302131,-1.49166032212924e-154 2.68156222893142e+154,-2.68156670066134e+154 1.49165907838805e-154,-1.90979621186875e-313 2.68157245827654e+154,2.68163574874448e+154 -2.68156734360361e+154,-2.68151938993771e+154 -2.68155551411858e+154,-2.00004196166992 -2.68156062879135e+154,-1.49167810419924e-154 2.68157245827552e+154,-2.68156670066134e+154 -1.49166850388797e-154,2.00005912780762 2.68154400610394e+154,2.00002479553223 1.49166405736692e-154,-1.49167810419924e-154 -2.68155551411733e+154,1.99997901916504 2.00002527505842,1.99999618530273 1.49166992645285e-154,1.49171509090483e-154 2.00000620157228,7.42698526837845e-313 -4.77748224636526e-314,2.68153089795157e+154 -1.99999070302005,-2.68161273271677e+154 2.00000620157254,2.68158971668906e+154 -2.00000238687552,-2.68154240596543e+154 1.99999642506625,2.68155263531108e+154 1.49166690249835e-154,1.99997901916504 2.38754457499187e-313,1.49168948472404e-154 -2.00002146036292,1.49165392058404e-154 5.33492939607011e-315,-2.68156670066134e+154 2.00002527506038,-2.68154240596543e+154 -2.68154656344073e+154,2.68163574874448e+154 1.49166405736728e-154,-2.00000762939453 -1.49166334608454e-154,2.68158971668906e+154 -1.99998784199785,-2.68156670066134e+154 -2.68157757294904e+154,2.68158971668906e+154 -2.00000238687675,1.99999618530273 2.68154912077759e+154,1.49166672367444e-154 2.68155295678234e+154,-1.49164751903885e-154 1.49166690249885e-154,1.99999618530273 1.49166192351921e-154,-1.49170228781443e-154 -2.68157757294913e+154,-1.49167810419924e-154 2.00002527506045,0 -2.68159547430487e+154,1.99997901916504 -1.49167846184837e-154,2.68155263531108e+154 -2.00000810892376,1.49165392058404e-154 1.49166992645506e-154,-1.49166032212924e-154 -2.00000810892452,0 2.68159035963361e+154,-1.49167810419924e-154 1.99999642506765,-1.49164751903885e-154 -2.000008108924,2.68155263531108e+154 2.00002527506162,-2.00004196166992 2.68155295678304e+154,-2.68154240596543e+154 -4.77748556055761e-314,-2.00000762939453 -1.99999451771861,2.00005912780762 1.49165907838811e-154,0 2.68154400610517e+154,1.49166672367444e-154 1.49166192351939e-154,-2.68161273271677e+154 -1.4916827295453e-154,-1.49164751903885e-154 -1.49166334608517e-154,2.68158971668906e+154 2.68156222893313e+154,2.68153089795157e+154 9.02147853427108e-314,-1.49164751903885e-154 -1.99999070302212,2.00005912780762 1.49165907838883e-154,-2.68154240596543e+154 -2.00000810892535,-2.68156670066134e+154 5.33495857558715e-315,2.68163574874448e+154 -1.99998784199889,1.49171509090483e-154 -1.49168272954591e-154,1.99997901916504 -1.11434731760397e-313,1.99997901916504 1.99999261037016,1.49171509090483e-154 -1.49167277158591e-154,-1.49166032212924e-154 -2.00001573831798,2.00002479553223 -1.11434722560894e-313,1.99997901916504 -2.68154656344175e+154,-2.00004196166992 1.99999928609015,-2.00000762939453 1.49166405736776e-154,2.00005912780762 -1.99999737874144,-2.00000762939453 2.38754467726346e-313,-2.00004196166992 -2.00002146036325,-2.00004196166992 9.02147582036849e-314,0 5.33492602160175e-315,0 -2.68155167811349e+154,2.68153089795157e+154 -2.5997441443059e-313,0 -2.68155167811335e+154,-1.49164751903885e-154 -2.00001573831625,2.68155263531108e+154 2.68154912077667e+154,1.49171509090483e-154 9.02147408422181e-314,2.68163574874448e+154 -2.00001573831522,1.49166672367444e-154 -2.59974400117508e-313,1.99997901916504 -2.00000238687481,-2.68154240596543e+154 -2.68155167811241e+154,-1.99998760223389 2.00001955301132,2.68155263531108e+154 1.99999261036789,-1.99997043609619 1.53874594062511e-313,-5.51718905650971e-313 -2.0000214603595,-1.49167810419924e-154 -1.4916727715824e-154,-1.49166032212924e-154 -2.00001573831325,2.68153089795157e+154 1.49166405736593e-154,7.42698526837845e-313 2.00000620156989,-2.00000762939453 1.49165907838618e-154,-2.68156670066134e+154 2.00000620156926,2.68158971668906e+154 1.49166992645031e-154,1.49171509090483e-154 -2.68156062878785e+154,-1.49164751903885e-154 1.49167561671239e-154,2.00002479553223 -2.68156062878763e+154,-5.51718905650971e-313 2.00001192361408,-2.00004196166992 2.00002527505432,-2.68154240596543e+154 -1.49167277158057e-154,1.49165392058404e-154 1.49166405736494e-154,-1.49167810419924e-154 1.9999992860863,0 -2.00000810891552,2.68158971668906e+154 -1.49166850388331e-154,7.42698526837845e-313 -1.99999737873813,-2.68151938993771e+154 -2.68156734359546e+154,2.68163574874448e+154 2.0000062015676,-1.49166032212924e-154 -1.96314477436526e-313,-2.68156670066134e+154 2.00001192361385,-2.00000762939453 1.53874562313853e-313,1.49165392058404e-154 -2.68155167810965e+154,7.42698526837845e-313 2.68156222892217e+154,1.49166672367444e-154 -4.77747751914516e-314,2.68158971668906e+154 -1.49166050095117e-154,3.81959242373749e-313 2.68156222892241e+154,2.68158971668906e+154 -1.96314471542323e-313,-5.51718905650971e-313 -2.6815516781091e+154,2.68163574874448e+154 -2.6815852449479e+154,-1.49166032212924e-154 3.02414251728042e-313,7.42698526837845e-313 -2.00002146035502,3.81959242373749e-313 -1.49167277157904e-154,1.49168948472404e-154 -2.00000238686834,2.00005912780762 1.53874537447529e-313,2.68155263531108e+154 -1.99999737873607,1.99999618530273 -1.99998784199284,2.68155263531108e+154 -1.4916784618399e-154,-1.49170228781443e-154 2.00002527504983,2.68155263531108e+154 1.49166192351509e-154,2.00005912780762 -1.99998784199254,-2.00000762939453 -2.68159547428898e+154,2.68158971668906e+154 2.00002527504905,1.49171509090483e-154 -2.00000238686533,1.99997901916504 -2.68155167810613e+154,-1.49167810419924e-154 1.53874498233539e-313,2.00002479553223 2.68154400609645e+154,1.49166672367444e-154 -1.49166334608003e-154,-1.99997043609619 -1.11434579509127e-313,2.00005912780762 -1.96314408563775e-313,-1.49166032212924e-154 2.0000119236073,7.42698526837845e-313 -1.99999070301473,-2.00004196166992 1.49165907838322e-154,3.81959242373749e-313 -1.49166547992837e-154,0 2.68155807144643e+154,-2.00000762939453 2.68158013026827e+154,1.99997901916504 1.49167561670661e-154,-1.49170228781443e-154 1.49166690249369e-154,2.68153089795157e+154 -1.11434562365049e-313,-2.68156670066134e+154 -1.49166547992777e-154,1.49171509090483e-154 -1.99998784199075,0 2.00002527504526,1.99999618530273 2.68155807144465e+154,1.99999618530273 2.00002527504476,-2.00000762939453 -2.68159547428246e+154,1.49165392058404e-154 2.38754281937901e-313,-2.68156670066134e+154 1.49168557466327e-154,1.49168948472404e-154 -1.49166547992681e-154,2.68158971668906e+154 -2.68159547428131e+154,2.68158971668906e+154 1.49165907838152e-154,1.49168948472404e-154 2.00001192360261,-2.00000762939453 1.49166690249208e-154,-2.68151938993771e+154 -1.49166334607815e-154,2.68153089795157e+154 -2.68154656342954e+154,1.49166672367444e-154 3.02414143962444e-313,1.49165392058404e-154 -2.68157757292587e+154,1.49165392058404e-154 2.38754269487446e-313,2.68158971668906e+154 -1.49167277157213e-154,2.00002479553223 -1.49168272953151e-154,-2.68154240596543e+154 -1.99998784198928,-1.49170228781443e-154 2.00001192360224,2.68163574874448e+154 -1.49166334607806e-154,1.99997901916504 -1.11434521742972e-313,-2.68161273271677e+154 2.00001192360216,-2.68156670066134e+154 -1.99999737873211,1.49171509090483e-154 -2.00002146034459,-1.49170228781443e-154 2.68154912076498e+154,2.68158971668906e+154 2.68154400609209e+154,2.00002479553223 2.68154400609169e+154,1.49171509090483e-154 2.68155807144182e+154,2.68155263531108e+154 2.68157245824948e+154,1.49171509090483e-154 1.99999642505676,2.00002479553223 2.68155807144104e+154,-1.99997043609619 2.68155295676816e+154,1.49165392058404e-154 -2.68157757292089e+154,-2.68156670066134e+154 1.49168557465991e-154,-1.49164751903885e-154 -1.99999737873059,2.68158971668906e+154 -1.49166850387287e-154,-1.90979621186875e-313 1.9999992860793,-2.00000762939453 -1.49168841979196e-154,-2.68156670066134e+154 2.00002527504042,1.49165392058404e-154 1.49166405735998e-154,2.68155263531108e+154 1.4916669024913e-154,-2.68154240596543e+154 2.68156222890513e+154,-2.68151938993771e+154 2.68157245825102e+154,-1.49164751903885e-154 2.38754257867022e-313,-1.99997043609619 -2.68154656342867e+154,-2.68154240596543e+154 -2.68155167810157e+154,2.00002479553223 -1.49167846183403e-154,-2.68154240596543e+154 -2.68157757292432e+154,-5.51718905650971e-313 2.00000620155632,2.68155263531108e+154 1.49166690249207e-154,2.00002479553223 -1.49166547992664e-154,1.99997901916504 -1.99999070301219,2.00002479553223 -2.68154656342941e+154,1.49166672367444e-154 1.49167988440014e-154,-2.68156670066134e+154 -1.99999737873223,-2.00000762939453 -2.00000810890461,-1.99997043609619 1.49166690249182e-154,1.49168948472404e-154 2.00002527504179,2.68155263531108e+154 1.9999964250575,-2.68154240596543e+154 1.99999642505734,1.49168948472404e-154 1.53874420092116e-313,-1.49164751903885e-154 -1.99999070301133,2.68155263531108e+154 -2.68155551410586e+154,-5.51718905650971e-313 2.68154912076485e+154,-1.99998760223389 1.9999897493372,1.99997901916504 1.49166690249163e-154,2.00005912780762 -2.68159547427899e+154,-1.49170228781443e-154 -1.49167277157135e-154,1.99999618530273 -2.68155551410563e+154,-2.00000762939453 1.53874415694932e-313,-2.68154240596543e+154 -2.68154656342768e+154,1.49168948472404e-154 1.53874408313591e-313,1.99997901916504 2.68155295676822e+154,-2.68151938993771e+154 -2.6815516781e+154,-1.99998760223389 2.68156222890265e+154,1.49165392058404e-154 -2.59974188859979e-313,1.49165392058404e-154 -2.68156734357513e+154,2.68153089795157e+154 -2.68156734357495e+154,-5.51718905650971e-313 -1.49166050094545e-154,0 2.68157245824689e+154,-1.99997043609619 -1.99998784198682,2.68153089795157e+154 -2.00001573829473,2.68163574874448e+154 2.00001192359725,2.68155263531108e+154 -2.00000238685422,-1.99997043609619 2.68159035960085e+154,2.68155263531108e+154 2.68155807143965e+154,2.00005912780762 -1.49167846183047e-154,-1.49167810419924e-154 2.38754204379475e-313,2.00002479553223 -2.00000810889892,-2.68161273271677e+154 -1.1143445203525e-313,-1.99998760223389 2.6815622288984e+154,2.68153089795157e+154 -2.00001573829295,-1.90979621186875e-313 -2.00001573829276,-2.68156670066134e+154 -1.49168272952614e-154,-1.49170228781443e-154 -2.68156062877473e+154,2.68155263531108e+154 1.99999261035689,1.99997901916504 -2.68156734356865e+154,-2.68154240596543e+154 -2.59974130970307e-313,2.68155263531108e+154 2.68154400608711e+154,1.99999618530273 2.68157245824064e+154,-1.90979621186875e-313 5.33463066421801e-315,-2.68156670066134e+154 -2.00000810889579,2.68158971668906e+154 2.00001955298692,2.68155263531108e+154 -2.00001573828985,-2.00000762939453 -2.00002146033571,2.00002479553223 1.49166992643345e-154,1.49168948472404e-154 -1.49167277156452e-154,2.00005912780762 -1.49168272952362e-154,-2.68156670066134e+154 -1.11434404254161e-313,2.68163574874448e+154 3.02414013776146e-313,-2.68161273271677e+154 9.02144315768864e-314,7.42698526837845e-313 -2.68156062877153e+154,3.81959242373749e-313 -1.99998784198332,-5.51718905650971e-313 1.49166992643212e-154,-2.00000762939453 -1.99998784198303,2.68158971668906e+154 1.49166690248729e-154,1.49168948472404e-154 1.4916855746532e-154,-1.90979621186875e-313 2.68158013024526e+154,-1.49164751903885e-154 9.02144194376935e-314,-2.68151938993771e+154 -1.96314208076876e-313,2.00005912780762 2.00001955298368,-2.68161273271677e+154 -2.59974078372078e-313,-2.68161273271677e+154 -2.00000238684533,-1.99997043609619 -2.00001573828565,-2.68151938993771e+154 -2.68155551409724e+154,1.49171509090483e-154 1.53874278270572e-313,2.00005912780762 -1.49168841978328e-154,-1.99997043609619 1.53874281674685e-313,2.68153089795157e+154 2.68155295676091e+154,-1.49167810419924e-154 -1.99999070300496,2.00005912780762 -2.68156734356052e+154,-1.49164751903885e-154 -2.00001573828533,3.81959242373749e-313 1.9999964250508,2.68163574874448e+154 -1.49168272952062e-154,1.49165392058404e-154 -1.96314193215382e-313,-2.00000762939453 9.02144055643301e-314,1.99997901916504 9.0214404171065e-314,-1.90979621186875e-313 -2.68155167809246e+154,-1.49164751903885e-154 5.33457149491626e-315,-1.49166032212924e-154 -2.68156734356033e+154,-1.49170228781443e-154 -1.99999737872447,1.99999618530273 9.02143905299125e-314,1.49165392058404e-154 1.49166992642952e-154,-2.68154240596543e+154 1.49166992642981e-154,-2.68151938993771e+154 2.68157245823251e+154,-2.00004196166992 -2.68154656341933e+154,1.49166672367444e-154 -1.99999737872495,-1.49164751903885e-154 2.00002527502804,-2.00004196166992 -2.6815775729055e+154,3.81959242373749e-313 -4.77744814842471e-314,-1.49164751903885e-154 -2.68158524491451e+154,-1.99997043609619 1.49167561669196e-154,1.49171509090483e-154 -4.77744740782031e-314,1.49166672367444e-154 1.99999642505021,2.68163574874448e+154 -1.49166547992088e-154,-2.00000762939453 -2.68156734356017e+154,1.49171509090483e-154 -2.68158524491546e+154,-2.00004196166992 2.0000252750287,2.68158971668906e+154 1.53874281832786e-313,-2.68161273271677e+154 1.49165907837604e-154,1.49171509090483e-154 2.00001955298291,-2.68156670066134e+154 5.33457142574707e-315,3.81959242373749e-313 -2.59974065264517e-313,3.81959242373749e-313 2.68159035958875e+154,2.68158971668906e+154 1.49166992643062e-154,-1.49166032212924e-154 1.4916640573558e-154,1.49171509090483e-154 2.68155295676114e+154,1.49166672367444e-154 -1.49166850386502e-154,2.68163574874448e+154 1.49166992643067e-154,0 -1.11434366640944e-313,1.99999618530273 2.00001955298282,2.68153089795157e+154 -1.49167846182392e-154,-2.68154240596543e+154 1.49166405735555e-154,-1.90979621186875e-313 -2.68155167809258e+154,2.68153089795157e+154 1.99999928607377,-2.68156670066134e+154 -2.68155551409704e+154,-1.49164751903885e-154 -2.68158524491498e+154,2.00005912780762 1.49166192350666e-154,3.81959242373749e-313 1.99999261035287,1.49165392058404e-154 -1.99998784198121,-2.00000762939453 -1.49166850386321e-154,-1.49166032212924e-154 -1.49168841978111e-154,-2.68156670066134e+154 -1.99999451770092,-2.68151938993771e+154 -1.9999878419808,-1.49164751903885e-154 2.68155807143194e+154,2.00005912780762 -1.49168841978101e-154,-1.49164751903885e-154 -1.99999737872355,-1.49167810419924e-154 -1.49168841978029e-154,-5.51718905650971e-313 -2.68155551409459e+154,1.99999618530273 1.49166192350564e-154,3.81959242373749e-313 9.02143563356292e-314,-1.99997043609619 -2.68158524490945e+154,2.68163574874448e+154 1.49166405735376e-154,-1.49167810419924e-154 -2.59974016223561e-313,2.68153089795157e+154 -2.68154656341689e+154,1.49168948472404e-154 -2.68158524491025e+154,2.68158971668906e+154 1.49166992642721e-154,-2.00004196166992 -2.68159547425725e+154,-2.68154240596543e+154 -1.49166547992003e-154,2.68155263531108e+154 1.53874251304469e-313,-2.68154240596543e+154 -1.49167846182205e-154,1.49166672367444e-154 -2.00000810888845,-1.49166032212924e-154 2.68155807143208e+154,-2.68151938993771e+154 2.68155295675924e+154,-1.49170228781443e-154 2.38754091549704e-313,-2.68161273271677e+154 1.49167988438828e-154,2.68155263531108e+154 -1.49167277156061e-154,-2.68151938993771e+154 2.68154400608293e+154,-1.90979621186875e-313 -1.49168272952036e-154,-2.68161273271677e+154 -1.49167277156141e-154,-2.68161273271677e+154 1.99999928607381,2.00005912780762 1.49166992643007e-154,-1.99997043609619 2.68154400608272e+154,-5.51718905650971e-313 1.49168557465106e-154,2.68158971668906e+154 -1.49166334607239e-154,-1.99998760223389 -1.99999070300448,7.42698526837845e-313 -1.49168841978231e-154,1.49171509090483e-154 -2.68154656341897e+154,2.00005912780762 1.49166690248637e-154,2.00005912780762 -2.00002146033007,1.99997901916504 2.68154400608288e+154,-1.99997043609619 -2.68158524491459e+154,7.42698526837845e-313 1.49166690248643e-154,-1.99997043609619 2.6815724582323e+154,-1.90979621186875e-313 1.99999642505048,-1.90979621186875e-313 -1.49168272952022e-154,-5.51718905650971e-313 2.0000195529819,-1.49166032212924e-154 9.02143952630614e-314,2.68155263531108e+154 1.49167561669177e-154,1.49166672367444e-154 -1.49166850386362e-154,-1.49164751903885e-154 -2.68159547425934e+154,2.68153089795157e+154 2.68157245823162e+154,-2.00000762939453 1.49166690248626e-154,2.68155263531108e+154 -1.99999070300431,1.49166672367444e-154 2.68154400608244e+154,2.68158971668906e+154 2.68159035958656e+154,2.68158971668906e+154 -2.00002146032975,1.49171509090483e-154 -2.00001573828382,2.00002479553223 1.53874261487162e-313,-1.99997043609619 -2.68156062876898e+154,-5.51718905650971e-313 1.4916590783754e-154,-5.51718905650971e-313 -2.0000157382838,-2.68154240596543e+154 -4.77744718746703e-314,1.49171509090483e-154 2.00001192358656,-5.51718905650971e-313 2.68154400608235e+154,-2.68151938993771e+154 1.49166192350663e-154,7.42698526837845e-313 1.49166690248624e-154,-2.00004196166992 -2.00002146032983,2.68155263531108e+154 -2.00001573828394,2.00002479553223 1.49167988438845e-154,-2.68161273271677e+154 1.49167988438844e-154,2.00005912780762 -1.49166547992065e-154,1.49166672367444e-154 -1.49166547992066e-154,-2.68156670066134e+154 2.68155807143271e+154,-2.68161273271677e+154 -1.96314179939838e-313,1.49166672367444e-154 -1.99999451770165,3.81959242373749e-313 2.68154912075541e+154,-5.51718905650971e-313 1.49168557465108e-154,-1.99998760223389 -1.99999070300432,2.68163574874448e+154 -1.1143434494158e-313,2.68158971668906e+154 1.53874258947665e-313,-2.68151938993771e+154 2.68158013024017e+154,3.81959242373749e-313 -2.00000810888872,2.68163574874448e+154 2.68155807143236e+154,-1.49167810419924e-154 -1.49166850386356e-154,-1.49164751903885e-154 -2.68155167809154e+154,-1.99998760223389 2.00001192358645,-2.68161273271677e+154 2.68154912075501e+154,1.99999618530273 2.68157245823149e+154,-1.49167810419924e-154 -1.96314180162167e-313,2.68163574874448e+154 -1.99999451770169,-2.00000762939453 -1.99999070300437,2.68158971668906e+154 1.99999261035274,-2.68151938993771e+154 -2.68155551409609e+154,-5.51718905650971e-313 -2.59974052058142e-313,-2.68156670066134e+154 1.53874261299417e-313,2.68163574874448e+154 1.49166992642983e-154,-2.68151938993771e+154 -1.49166050094134e-154,2.68153089795157e+154 -1.49166850386429e-154,2.68153089795157e+154 1.99999642505064,2.68155263531108e+154 -1.49166850386436e-154,-2.00000762939453 -1.99999737872495,-1.99998760223389 1.49167988438916e-154,2.00005912780762 -4.77744846808518e-314,-2.68154240596543e+154 2.68159035958788e+154,1.49165392058404e-154 -1.99998784198181,2.68158971668906e+154 -2.00000810889039,1.99997901916504 2.681590359588e+154,2.68163574874448e+154 -1.49166547992106e-154,-1.99998760223389 1.99999642505074,1.99997901916504 -1.49167846182373e-154,-1.99998760223389 -2.00000810889059,-2.68161273271677e+154 -2.68156734356045e+154,-2.00000762939453 -1.49166547992108e-154,0 1.49165907837587e-154,2.68163574874448e+154 2.68156222888753e+154,2.00002479553223 2.68159035958808e+154,1.99997901916504 -2.68158524491549e+154,-2.68154240596543e+154 2.00000620154213,0 -1.96314193714388e-313,-2.68156670066134e+154 -1.49166547992115e-154,-1.49170228781443e-154 2.68156222888783e+154,-1.49167810419924e-154 2.68156222888787e+154,-1.99998760223389 5.33457513618007e-315,-1.49170228781443e-154 2.68157245823399e+154,-5.51718905650971e-313 9.02144086818844e-314,-1.90979621186875e-313 1.99999642505121,-2.00000762939453 -2.00002146033204,-1.49166032212924e-154 -1.49168272952144e-154,-2.68161273271677e+154 2.68155807143447e+154,2.00002479553223 -1.99999737872605,-1.99997043609619 2.68154400608454e+154,1.49171509090483e-154 -1.99999070300585,-5.51718905650971e-313 2.00001955298551,1.49165392058404e-154 -1.9999973787272,-2.68161273271677e+154 2.68154912075929e+154,-1.99998760223389 9.02144605884211e-314,2.68155263531108e+154 2.38754176420301e-313,1.99997901916504 1.4916855746567e-154,2.68163574874448e+154 1.49166405735802e-154,-1.49167810419924e-154 2.00001955298985,-1.49166032212924e-154 -4.77745834149305e-314,-2.68151938993771e+154 -2.00000238685264,2.68158971668906e+154 2.00001955299013,-1.49164751903885e-154 1.49167988439538e-154,1.49171509090483e-154 2.68157245824358e+154,-2.68161273271677e+154 2.00002527503619,-1.49164751903885e-154 -2.0000023868532,2.68155263531108e+154 -2.00001573829392,7.42698526837845e-313 -1.99999451770674,2.00005912780762 1.49165907837942e-154,-1.49164751903885e-154 2.00001192359742,2.00005912780762 -2.59974172669447e-313,-5.51718905650971e-313 -2.68158524492808e+154,2.68158971668906e+154 2.68154912076248e+154,-2.68161273271677e+154 2.38754218465287e-313,-2.00004196166992 1.49167988439738e-154,-1.49167810419924e-154 -4.77746069275146e-314,2.68158971668906e+154 2.68157245825091e+154,-2.68151938993771e+154 -2.68159547427887e+154),(-1.49167810419924e-154 1.49168557465228e-154,-2.68151938993771e+154 -1.99999070300523,2.00005912780762 -1.49166334607302e-154,1.49166672367444e-154 -2.00000810889164,2.68163574874448e+154 2.00001955298347,2.68153089795157e+154 2.68158013024382e+154,-1.49167810419924e-154 1.49168557465228e-154)))
> any idea?
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
