[postgis-devel] Re: postgis/geos profiling
strk at refractions.net
Fri Sep 24 14:48:06 PDT 2004
On Fri, Sep 24, 2004 at 09:51:53AM -0700, Martin Davis wrote:
> Hmmm... It seems odd that the times for distance() are relatively
> independent of the number of 'true' cases. Any idea why this should be?
> The times for intersects are almost exactly proportional to the number
> of true results, which is what I would expect.
The distance() function computes the minimum 2d distance
between two geometries.
Since the "minimum" distance cannot be smaller then 0, as
soon as an intersection is found "distance()" returns 0.
The segment scanner might encountered an intersection only
in the last scanned tuple of segments.
For example the last segment of the last hole of the polygon
intersects the last segment of the linestring...
Or it could catch it immediately.
False results, on the other hand, force distance() to scan the whole
segment set before giving an answer (never short-cut).
True results represent cases in which distance() used it's internal
short-circuit.
Try analyzing the output under this light...
--strk;
> Maybe it's not right just counting the number of "true" results. After
> all, both methods spend time computing for "false" results as well.
> Although I guess the index removes most of the false results. Is there
> any way to get a count of how many tests were actually performed by the
> functions?
> Martin Davis, Senior Technical Architect
> Vivid Solutions Inc. www.vividsolutions.com
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> > -----Original Message-----
> > From: strk at refractions.net [mailto:strk at refractions.net]
> > Sent: September 24, 2004 5:39 AM
> > To: Martin Davis
> > Cc: postgis-devel at postgis.refractions.net
> > Subject: Re: postgis/geos profiling
> > Some profiling over distance() vs intersects().
> > The profiler script is in CVS (utils/profile_intersects.pl).
> > The scripts takes two spatial tables.
> > The first is for extent extraction.
> > The extent of first table is subdivided in BPSxBPS cells
> > and each of the features in second spatial table is
> > checked for intersection with each cell.
> > - index scan is been disabled ! -
> > At the end of each BPS query loop a summary is printed
> > containing worst and best runs in percentile one over the
> > other (distance, intersects).
> > 't' is the number of queries returning 'true'.
> > Type: MULTILINESTRING
> > Rows: 3183
> > bps t intr dist intr/dist
> > 2 371 145254 152154 0.95
> > 2 769 225747 159403 1.41
> > 2 1801 467103 149191 3.13
> > 2 283 118823 155096 0.76
> > 2 (min/max/avg) 0.76 3.13 1.56
> > 2 worst 313% 131%
> > 2 best 31% 76%
> > These are large boxes. The cell which contains MORE
> > intersecting features is the one in which intersects() does
> > is worst job. The one with less intersecting cells give the
> > best intersects() run.
> > Rows: 3183
> > 3 0 49965 158799 0.31
> > 3 346 134842 161126 0.83
> > 3 325 118629 165073 0.71
> > 3 804 236623 153393 1.54
> > 3 459 163660 156635 1.04
> > 3 160 87627 161721 0.54
> > 3 872 262444 156008 1.68
> > 3 243 109996 159614 0.68
> > 3 51 61193 162184 0.37
> > 3 (min/max/avg) 0.31 1.68 0.85
> > 3 worst 168% 322%
> > 3 best 59% 31%
> > Here the relation between true values and intr/dist factor
> > still holds true.
> > --strk;
