[postgis-devel] loader incompatibility
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Apr 1 01:11:16 PST 2005
Hi strk,
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: 01 April 2005 08:59
> To: postgis-devel at postgis.refractions.net
> Subject: [postgis-devel] loader incompatibility
> Yes, it is again too late for this, but before we
> release 1.0.0, should we somehow handle the incompatibilities
> between 0.x and 1.x loader ?
> The new shp2pgsql will produce HEXEWKB queries.
> The old shp2pgsql will produce GeometryFromText(EWKT) queries.
> The old shp2pgsql will work against new postgis.
> The new shp2pgsql will NOT work against old postgis.
I guess you meant to type pgsql2shp? ;)
> I asked before, in the last mail of a long solo thread:
http://postgis.refractions.net/pipermail/postgis-devel/2004-October/000537.h
tml
> My current concern is: is people have both 0.x and 1.x
> postgis installed they need both 0.x and 1.x loader too,
> while current installation rule would make one override
> the other.
I must say I don't see this as much of as issue. Since the major number has
been bumped, people expect 1.0 to be different to 0.9.x, so my personal
expectation would be to have to re-generate new SQL from my original
shapefiles and reload them into the database, which is not particularly
difficult. For people who want to upgrade from 0.9.x to 1.0 then they can
just dump and then reload if they've already loaded their shapefiles without
touching shp2pgsql/pgsql2shp....
Looks at the source... I see in pgsql2shp that the main loop declares a
cursor and then does a "FETCH %d FROM cur", where %d is rowbuflen which
defaults to 100. As far as I can see, this FETCH is only called once and so
the resulting shapefile will be truncated to 100 records maximum - or are my
eyes deceiving me?
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
