[postgis-devel] loader incompatibility
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Apr 1 01:49:36 PST 2005
Hi strk,
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: 01 April 2005 10:26
> To: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] loader incompatibility
> On Fri, Apr 01, 2005 at 10:11:16AM +0100, Mark Cave-Ayland wrote:
> > Hi strk,
> > > Sent: 01 April 2005 08:59
> > > To: postgis-devel at postgis.refractions.net
> > > Subject: [postgis-devel] loader incompatibility
> > > Yes, it is again too late for this, but before we
> > > release 1.0.0, should we somehow handle the incompatibilities
> > > between 0.x and 1.x loader ?
> > > The new shp2pgsql will produce HEXEWKB queries.
> > > The old shp2pgsql will produce GeometryFromText(EWKT) queries.
> > > The old shp2pgsql will work against new postgis.
> > > The new shp2pgsql will NOT work against old postgis.
> > I guess you meant to type pgsql2shp? ;)
> Nope. I meant shp2pgsql.
> pgsql2shp works on every postgis version as it talks to the
> database thus it is able to extract postgis version before proceding.
Oops, I totally read that out of context :)
(cut)
> Fair enough. Your opinion lowers my paranoia level ;)
Yeah I'd be inclined to add support if for example we were going from say
1.0.0 to 1.0.1, but for a major bump I think most people would reload data
or dump/restore (I know we will).
> > Looks at the source... I see in pgsql2shp that the main
> loop declares
> > a cursor and then does a "FETCH %d FROM cur", where %d is rowbuflen
> > which defaults to 100. As far as I can see, this FETCH is
> only called
> > once and so the resulting shapefile will be truncated to
> 100 records
> > maximum - or are my eyes deceiving me?
> Execution of that FETCH query is inside a while(1) loop
> (264). The loop is explicitly broke by an empty result set.
> You can trmodify rowbuflen with an environmental variable
> (undocumented):
> ROWBUFLEN=1000 pgsql2shp db table
> ROWBUFLEN=100 pgsql2shp db table
> ROWBUFLEN=10 pgsql2shp db table
> ROWBUFLEN=1 pgsql2shp db table
Hmmm but as I see it the while() loop cycles through each of the 100 fetched
records and not each *set* of 100 records? I'd expect there to be an outer
loop somewhere with the "FETCH %d FROM cur" inside it, i.e. there should be
another outer while() loop somewhere around line 256....?
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
