[postgis-devel] Re: [postgis-users] Help with spatial query(bug??)
Martin Daly
Martin.Daly at cadcorp.com
Wed Apr 6 22:13:38 PDT 2005
Carl,
> Do you know where I can get a copy of ogc 96-015R1 (or its successor) as
> referenced in referencee [1] of 99-049 SF-SQL?
I believe that the successor to 96-015r1 - which should still be available via the OGC portal - is 01-101 (http://www.opengeospatial.org/docs/01-101.pdf), "OGC Abstract Specification Topic 1: Feature Geometry", which is identical ti ISO 19107.
Martin
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050407/56525d6c/attachment.bin>
