[postgis-devel] Ready for 1.0.0 FINAL ?
Devrim GUNDUZ
devrim at tdmsoft.com.tr
Thu Apr 14 09:35:24 PDT 2005
On Thu, 14 Apr 2005 strk at refractions.net wrote:
<snip>
> I'd release FINAL early next week, does anyone have open issues ?
I'm relatively new to PostGIS. I hope these warnings haven't been reported
before:
g++ -O2 -Wall -Wmissing-prototypes -Wpointer-arith
-Wdeclaration-after-statement -Wold-style-definition -Wendif-labels
-fno-strict-aliasing -g -O2 -fexceptions -fPIC -DUSE_VERSION=80
-DPOSTGIS_LIB_VERSION='"1.0.0RC6"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.0"'
-DPOSTGIS_BUILD_DATE='"2005-04-14 16:25:12"' -I/usr//include -DUSE_GEOS
-I/usr/local/include -DUSE_PROJ -I/usr/local/include -DAUTOCACHE_BBOX=1
-I/usr/src/redhat/BUILD/postgis-1.0.0-rc6/../../src/include -D_GNU_SOURCE
-c -o lwgeom_geos_wrapper.o lwgeom_geos_wrapper.cpp
cc1plus: warning: command line option "-Wmissing-prototypes" is valid for
Ada/C/ObjC but not for C++
cc1plus: warning: command line option "-Wdeclaration-after-statement" is
valid for C/ObjC but not for C++
cc1plus: warning: command line option "-Wold-style-definition" is valid
gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith
-DPOSTGIS_BUILD_DATE='"2005-04-14 16:29:51"' -I/usr//include -DUSE_GEOS
-DUSE_STATS -fpic
-c -o lex.yy.o lex.yy.c
wktparse.lex: In function `close_parser':
wktparse.lex:21: warning: old-style parameter declaration
lex.yy.c: In function `yy_get_next_buffer':
lex.yy.c:2847: warning: old-style parameter declaration
lex.yy.c: In function `yy_get_previous_state':
lex.yy.c:2979: warning: old-style parameter declaration
lex.yy.c: In function `input':
lex.yy.c:3086: warning: old-style parameter declaration
wktparse.lex: At top level:
lex.yy.c:3044: warning: 'yyunput' defined but not used
-DUSE_STATS -fpic
-c -o vsprintf.o vsprintf.c
vsprintf.c: In function `int_vasprintf':
vsprintf.c:44: warning: old-style parameter declaration
vsprintf.c: In function `vasprintf':
vsprintf.c:134: warning: old-style parameter declaration
gcc -g -Wall -I.. -I.
-I/usr/src/redhat/BUILD/postgis-1.0.0-rc6/../../src/interfaces/libpq -O2
-Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement
-Wold-style-definition -Wendif-labels -fno-strict-aliasing -DFRONTEND
-DSYSCONFDIR='"/usr/local/pgsql/etc"' -DUSE_VERSION=80
-c -o getopt.o getopt.c
getopt.c: In function `exchange':
getopt.c:184: warning: old-style parameter declaration
getopt.c: In function `_getopt_internal':
getopt.c:274: warning: old-style parameter declaration
getopt.c: In function `getopt':
getopt.c:605: warning: old-style parameter declaration
getopt.c: In function `getopt_long':
getopt.c:619: warning: old-style parameter declaration
cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e
's:@MODULE_FILENAME@:\$libdir/postgis.so:g;s:@POSTGIS_VERSION@:1.0
USE_GEOS=1 USE_PROJ=1
USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.3.0:g;s/@POSTGIS_BUILD_DATE@/2005-04-14
16:29:51/g' | grep -v '^#' > lwpostgis.sql
lwpostgis.sql.in:24: warning: extra tokens at end of #else directive
lwpostgis.sql.in:32: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:149: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:401: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:799: warning: extra tokens at end of #else directive
lwpostgis.sql.in:833: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:1819: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:1885: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2072: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2153: warning: extra tokens at end of #else directive
lwpostgis.sql.in:2155: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2172: warning: extra tokens at end of #else directive
lwpostgis.sql.in:2178: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2218: warning: extra tokens at end of #else directive
lwpostgis.sql.in:2220: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2233: warning: extra tokens at end of #else directive
lwpostgis.sql.in:2239: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2538: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2647: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2742: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2847: warning: extra tokens at end of #else directive
lwpostgis.sql.in:2887: warning: extra tokens at end of #endif directive
lwpostgis.sql.in:2953: warning: extra tokens at end of #endif directive
This is RHEL 4 and:
[root at buildfarm SPECS]# gcc -v
Reading specs from /usr/lib/gcc/i386-redhat-linux/3.4.3/specs
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
--infodir=/usr/share/info --enable-shared --enable-threads=posix
--disable-checking --with-system-zlib --enable-__cxa_atexit
--disable-libunwind-exceptions --enable-java-awt=gtk
--host=i386-redhat-linux
Thread model: posix
gcc version 3.4.3 20041212 (Red Hat 3.4.3-9.EL4)
Anyway, these don't stop PostGIS from compiling.
Regards,
Devrim GUNDUZ
TDMSoft Technical Manager
Teknoloji Destek Merkezi - http://www.TDMSoft.com.tr
Tel : +90.312.405.4016 Fax : +90.312.428.1902
PGP Key: www.TDMSoft.com.tr/devrimgunduz-tdmsoft.asc
