[postgis-devel] RPM development process
strk at refractions.net
Fri Apr 15 03:02:58 PDT 2005
1.0.0 will be out about monday, I don't think it's worth
releasing RC6 so far. About repository I wasn't talking about
final .rpm, but about config files for rpm generator (if any).
--strk;
On Fri, Apr 15, 2005 at 12:58:33PM +0300, Devrim GUNDUZ wrote:
> Hi,
> On Fri, 15 Apr 2005 strk at refractions.net wrote:
> >All binary packages are welcome!
> Ok, will send the rc6 RPM today.
> >Do you also need a Repository for your working files ?
> It's up to you. Either you can grant me commit access to an area; or I'll
> send you the RPMS and you'll commit.
> Regards,
> Devrim GUNDUZ
> Teknik Müdür
> Teknoloji Destek Merkezi - http://www.TDMSoft.com
> Tel : (312) 405 40 16 Fax: (312) 428 19 02
> PGP Key: www.TDMSoft.com/devrimgunduz-tdmsoft.asc
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
