[postgis-devel] 1.0 branch
Markus Schaber
schabi at logix-tt.com
Fri Apr 15 05:26:55 PDT 2005
Hi, Strk,
strk at refractions.net schrieb:
> - <your feature-request here>
I have around 66k worth of changes for jdbc2 pending, including working
optional JTS support, extended regression tests and a new autoprobing
DriverWrapper that detects the PostGIS Server version on connection time
to decide whether to send EWKT or HexWKB to the server.
I held those changes back as I did not want to destabilize the 1.0.0
branch. I hope I can commit them on Monday after merging them and
running a first test against the new postgresql-8.1dev-400.jdbc3.jar.
The JTS support makes it possible to create a new kind of regression
test that runs the same spatial operations in JTS and on the Server and
then compare the results. However, there are no such tests yet.
Markus
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050415/acedbedc/attachment.sig>
