[postgis-devel] 1.0 branch
Jean David TECHER
davidtecher at yahoo.fr
Fri Apr 15 06:34:48 PDT 2005
Hi again Sandro
When I compiled in Windows (with TeXLive latex) the doc by
pdfxmltex postgis.fo
in postgis/doc/postgis.pdf (see attached file)
there are others contributors..;Great to see Klaus has been added :-)
----- Original Message -----
To: <postgis-devel at postgis.refractions.net>
Cc: "Paul Ramsey" <pramsey at refractions.net>
Sent: Friday, April 15, 2005 1:51 PM
Subject: [postgis-devel] 1.0 branch
> pgis_1_0 branch is set. 1.0.0 will come out from there.
> HEAD is open for changes. Here's a brief list of items
> for 1.1 that I've in mind and are not present in the TODO:
> - PGsql sources dependency drop
> - Full autoconf support
> - Special threatment of SRID=-1, dims=-1, type=GEOMETRY
> in geometry_columns
> - Better upgrade mechanism
> - Pre-8.0 port of new estimator code
> - Better regression tests (single load, multi operations)
> - contrib/ dir with WFSLocks and packaging files ?
> - <your feature-request here>
> Actual items to be work on will obviously require a scan of the TODO,
> and priority assignment, we have most notably:
> - network operations
> - multi-dimensional indexing
> --strk;
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: application/pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050415/58939600/attachment.pdf>
