RES: [postgis-devel] Autoprobing java source files
strk at refractions.net strk at refractions.net
Wed Apr 20 04:58:56 PDT 2005
On Wed, Apr 20, 2005 at 08:29:34AM -0300, Gustavo Henrique Sberze Ribas wrote:
> > > Now my question is whether this will work under non-posix
> > environments,
> > > especially the PostGIS/Windows packagers come in my mind.
> > Can I expect
> > > Windows java developers to have "find" installed?
>  Nope. But nevermind, we don't have "make" either :) .
> >  but on windows in order to getting .jar
> > they have to use MinGW/Msys (used to build postgis and
> > postgresql...) which
> > contains "find"
>  Nope. Just the SDK from Sun suffices.
>  A JAR file is nothing more than a .zip full of .class files
> organized in directories. If you want to make things easier
> for M$ Windows users you should consider delivering the JAR
> itself (not only the makefile) along with the binary distros.
Of course binary distros should have the .jar prebuilt.
>  Or, if I may abuse your good will, you could deliver an Ant
> (java version of "make") build.xml. :)
You're abusing :0
We're having a discussion about this on jts-devel.
I see ant could be invoked by make, but why having another
dependency ?
--strk;
> Best Regards,
> Gustavo
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
