[postgis-devel] pg_opclass and schema awareness
Markus Schaber
schabi at logix-tt.com
Wed Apr 20 08:05:04 PDT 2005
Hi, Strk,
strk at refractions.net schrieb:
>>>For Chris vision Markus patch is ok, as far as it consider
>>>USE_VERSION before attempting to call current_schema().
>>>I suggest Markus applies his patch with that modification
>>>in the both HEAD and 1.0 branch.
>>Hmm, schema support was introduced in V7.3, right?
> Search 'schema' in lwpostgis.sql.in and you'll find out.
> I was thinking to define HAS_SCHEMA to avoid this, but
> didn't do it yet...
Thanks. It looks like the definition in question already is in a
USE_VERSION >= 73 block :-)
I committed it in both 1.0.0 and HEAD branches.
Markus
