[postgis-devel] RE: estimates problems and 1.0.0 delay
Ron Mayer
rm_postgis at cheapcomplexdevices.com
Thu Apr 21 14:57:50 PDT 2005
strk at refractions.net wrote:
> Mark, BTW, here is another warm.
> Single point in table, invalid join selectivity:
I think I've actually encountered this issue in a real (non-contrived test case) query,
after all the tables were just ANALYZEd immediatelly before running the query.
fli=# select * from rtgr.landpoly,
userfeatures.area_features
where rtgr.landpoly.the_geom && userfeatures.area_features.the_geom
and intersects(rtgr.landpoly.the_geom,userfeatures.area_features.the_geom)
and userfeatures.area_features.feature_id=7;
ERROR: invalid join selectivity: 1.003720
What's happening here is that the "landpoly" contains all the polygons for
landmarks in the county; and "area_features" is a user-defined polygon that
the user creates by drawing on a map with a mouse. There's nothing the
prohibits a user from drawing a polygon that encloses the entire county
(effectively saying that he wants to select all the landmarks).
When I do this, if I understand selectivity right, I guess you'd expect the
selectivity to be somewhere around one (so the estimaror is making a
very good guess, only 0.3% off); but in this case rounding pushed it
slightly above one. From the error message, I'm guessing it's saying
that values over 1 are not legal?
It make me wonder if we'd want something like this. (I also wonder
it for the stuff around line 724, but I wasn't hitting that condition.)
greenie postgis-1.0.0/lwgeom> diff -c lwgeom_estimate.c.~1~ lwgeom_estimate.c
*** lwgeom_estimate.c.~1~ Mon Apr 18 07:12:59 2005
--- lwgeom_estimate.c Thu Apr 21 14:49:36 2005
*** 984,989 ****
--- 984,991 ----
PG_RETURN_FLOAT8(DEFAULT_GEOMETRY_JOINSEL);
+ if ( rows_returned > total_tuples )
+ PG_RETURN_FLOAT8(1.0);
PG_RETURN_FLOAT8(rows_returned / total_tuples);
> strk=# explain analyze select * from t1 a, t1 b where a.g && b.g; NOTICE: LWGEOM_gist_joinsel called with jointype 0
> NOTICE: Working with relations oids: 4150592 4150592
> NOTICE: -- geomstats1 box: 1 1, 1 1
> NOTICE: -- geomstats2 box: 1 1, 1 1
> NOTICE: -- calculated intersection box is : 1 1, 1 1
> NOTICE: search_box contains histogram, returning 1
> NOTICE: selectivity1: 1 selectivity2: 1
> NOTICE: Rows from rel1: 1.000000
> NOTICE: Rows from rel2: 1.000000
> NOTICE: Estimated rows returned: 4.000000
> ERROR: invalid join selectivity: 4.000000
> What about using selectivity1 * selectivity2 ?
> It would allow use to avoid total_tuples lookup.
> Would it be correct ?
> --strk;
