[postgis-devel] Re: [postgis-users] Building PostGIS from Sunday CVS..without PostgreSQL Sources...OK ! ! !
Jean David TECHER
davidtecher at yahoo.fr
Tue Apr 26 02:55:32 PDT 2005
QUESTION 1:
> Here you're adding more server headers in case of a build against MINGW.
> Question is: who is requiring this ? Which source files are trying
> to include things which are not in PGBEINCLUDES (PostgreSQL Back-End
> includes) ? Is there a different server-headers layout for postgresql
> un unix and w32 systems ?
U need to tell PostGIS where to find file pwd.h, netdb.h which are locatd
in include/server/port and
include/server/port/win32..or else U will have a error
QUESTION 2:
> The value of DLSUFFIX sould be set by configure IMO, the "findstring"
> call replaced by an invocation of uname probably. What does uname -s
> returns there ?
uname -s returns
MINGW32_NT-5.1
Could do the invocation of uname..;Right :-)
QUESTION3:
> Am I missing something or the two blocks (MINGW or not) are
> exactly the same in both of the blocks above ?
Right again...:-) ...But I was in a hurry last sunday...I did'nt read again
my change
QUESTION 4:
> Why do you need to link statically against the libpq ?
Hum..Sorry But in Makefile.config.in when U do
PGFELIBS=@PGFELIBS@
doesn't work on Windows..I hat a error on a caracter ("squared" caracter
I had something like
PGFELIBS=-Lc:/PostgreSQL/lib [] -lpq
So that's the reason...I think U could change this...
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: "Jean David TECHER" <davidtecher at yahoo.fr>
Cc: <postgis-devel at postgis.refractions.net>
Sent: Tuesday, April 26, 2005 11:26 AM
Subject: Re: [postgis-users] Building PostGIS from Sunday CVS..without
> On Tue, Apr 26, 2005 at 11:03:34AM +0200, Jean David TECHER wrote:
> > My patch is attached to this mail (postgis_cvs.patch)...In order to
applyng
> > it (thanks to Gerald for patching :-))
> > The last thing to do - for people who wants to compil postgis on
windows -
> > is to take care of Docbook, iconv.dll and xsltproc
> > Else 'make install' wil stop for "make -C doc"
> This is true for all systems. Detecting iconv presence will allow
> us to build shp2pgsql with or without utf8 support w/out user (or
> packager usually) intervantion. Detecting xsltproc absence should
> skip attempt at generating docs. Note anyway that postgis packages
> come with documentation already generated, thus a make in doc
> *should* tells you "nothing to be done here" or something similar.
> Your mileage may vary of course... if this is not the case I'd
> drop the default attempt at making docs in order to avoid a
> dependency on xsltproc.
> Some comments and questions on the patch:
> > Here is the contense of the patch:
> > --- postgis/Makefile.config.in Tue Apr 19 10:41:21 2005
> > +++ postgis/Makefile.config.in Mon Apr 25 12:43:59 2005
> > @@ -71,9 +71,13 @@
> > PGCONFIG=@PGCONFIG@
> > PGFEINCLUDES=@PGFEINCLUDES@
> > +ifeq ($(findstring MINGW,$(MSYSTEM)),MINGW)
> > +PGBEINCLUDES=@PGBEINCLUDES@ @PGBEINCLUDES@/port
@PGBEINCLUDES@/port/win32
> > @PGBEINCLUDES@/port/win32/arpa
> > +PGFELIBS=$(shell @PGCONFIG@ --libdir)
> > +else
> > PGFELIBS=@PGFELIBS@
> > +endif
> > # Docbook
> > @@ -112,8 +116,13 @@
> > # DLL
> > -DLSUFFIX=@DLSUFFIX@
> > -DLFLAGS=@DLFLAGS@
> > + DLSUFFIX=.dll
> > + DLFLAGS=@DLFLAGS@
> > +else
> > + DLSUFFIX=@DLSUFFIX@
> > + DLFLAGS=@DLFLAGS@
> > +endif
> returns there ?
> > # END OF CONFIGURATION
> > --- postgis/loader/Makefile Mon Apr 18 14:46:48 2005
> > +++ postgis/loader/Makefile Mon Apr 25 12:40:44 2005
> > @@ -32,7 +32,13 @@
> > $(CC) $(CFLAGS) $(PGFEINCLUDES) -c $<
> > pgsql2shp$(EXE): $(OBJS) pgsql2shp.o PQunescapeBytea.o
> > + $(CC) $(CFLAGS) $(OBJS) PQunescapeBytea.o pgsql2shp.o $(LDFLAGS)
> > $(PGFELIBS)/libpq.a -o $@
> > +else
> > $(CC) $(CFLAGS) $(PGFELIBS) $(OBJS) PQunescapeBytea.o pgsql2shp.o
> > $(LDFLAGS) -o $@
> > +endif
> > shp2pgsql$(EXE): $(OBJS) shp2pgsql.o
> > $(CC) $(CFLAGS) $(OBJS) shp2pgsql.o $(LDFLAGS) -o $@
> > --- postgis/lwgeom/Makefile Wed Apr 20 15:17:37 2005
> > +++ postgis/lwgeom/Makefile Mon Apr 25 12:09:17 2005
> > @@ -13,21 +13,32 @@
> > # Shared library parameters.
> > NAME=lwgeom
> > +SHLIB =
> > lib$(NAME).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)$(DLSUFFIX)
> > +SHLIB_MAJOR = lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION)
> > +SHLIB_BARE = lib$(NAME)$(DLSUFFIX)
> > +SHLIB_LINK =
> > +else
> > SHLIB =
> > lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
> > -SHLIB_LINK = $(DLFLAGS)
> > +SHLIB_LINK = $(DLFLAGS)
> > +endif
> > MODULE_FILENAME = $(LPATH)/$(SHLIB)
> > # Postgis version and build date
> > -POSTGIS_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
> > USE_GEOS=$(USE_GEOS) USE_PROJ=$(USE_PROJ) USE_STATS=$(USE_STATS)
> > -POSTGIS_LIB_VERSION =
> > $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION).$(SO_MICRO_VERSION)
> > -POSTGIS_BUILD_DATE := $(shell date -u "+%Y-%m-%d %H:%M:%S")
> > + POSTGIS_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
> > + POSTGIS_LIB_VERSION =
> > + POSTGIS_BUILD_DATE := $(shell date -u "+%Y-%m-%d %H:%M:%S")
> > +else
> > +endif
> > @@ -87,8 +98,17 @@
> > all: $(GEOS_RULES) $(SHLIB) ../lwpostgis.sql
> > +#------------ It's for Win32 -----------------------------------
> > $(SHLIB): $(OBJS)
> > + dlltool --export-all --output-def lwgeom.def $(OBJS)
> > + dllwrap -o $@ --dllname $@ --def lwgeom.def $(OBJS)
> > $(SHLIB_LINK) -L$(shell pg_config --libdir) -lpostgres
> > + dlltool --dllname $@ --def lwgeom.def --output-lib liblwgeom.a
> > +else
> > $(CC) $(SHLIB_LINK) -o $(SHLIB) $(OBJS)
> > +endif
> This should be fine, except last dlltool call is for building
> the liblwgeom.a, which is not needed.
> --strk;
> > wktparse.tab.c: wktparse.y
> > $(YACC) -vd -p lwg_parse_yy wktparse.y
> > TECHER Jean David
> > 01MAP
> > Tél: 04 67 45 60 27
> > From: <strk at refractions.net>
> > Cc: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> > Sent: Monday, April 25, 2005 1:44 AM
> > > On Sun, Apr 24, 2005 at 07:39:38PM +0200, Jean David TECHER wrote:
> > > > Hi Sandro and PostGIS'ers,
> > > > Last Sunday, I decided to compil PostGIS from CVS (form sunday in
the
> > afternoon)...
> > > > Since the goal is to build PostGIS WITHOUT PostgreSQL sources but
from
> > the binairies installed on the computer
> > > > the tests on Windows for me is OK...Successfull...I did it for PG
8.0.2,
> > Geos 2.1.1 and Proj 4.4.9
> > > Good news!
> > > Weird I didn't change anything since your worried mails ;)
> > > > The only changes -I had to do - were to make few changes on:
> > > > -1/ postgis/Makefile.config.in
> > > > - 2/postgis/lwgeom/Makefile
> > > > - 3/postgis/loader/Makefile
> > > > For each file, I used
> > > > XXXXXXXXX
> > > > else
> > > > XXXXXXXXXX
> > > > endif
> > > I'd put the XXXXXX all in Makefile.config.in.
> > > > The changes in files are at the end of this files (sorry, I didn't
at
> > enough times to make patch... :-[ ....)
> > > > Since i'm not at job on Monday but Tuesday, I will do a resume doc
next
> > Tuesday
> > > > NOTICE: For creating postgis doc, I need to have
> > docbook-xslt-stylesheets, xlstproc and icon.dll installed on
> > Windows..Nevermind
> > > > Just 3 downloading to do.
> > > > cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis login
> > > > cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis co
postgis
> > > > cd postgis
> > > > autoconf
> > > > configure --enable-autotconf --with-geos=`which geos-config`
> > > If geos-config is in your PATH, which is what you expect using which,
> > there should be
> > > no need to be explicit. A simple --with-geos should work.
> > > > make
> > > > make install
> > > > cd regress
> > > > make
> > > > Regression Tests, Loading some data with the laoder (...) work
fine...
> > > Thanks! See you on Tuesday with patches then :)
> > > --strk;
========================================[postgis/Makefile.config.in ]=======
> > > > # Configuration Directives
> > > > # We recommend that you install the Proj4 and GEOS libraries
> > > > # referenced below to get the most use out of your PostGIS
> > > > # database.
> > > > # Set USE_PROJ to 1 for Proj4 reprojection support (recommended)
> > > > # Reprojection allows you to transform coordinate systems
> > > > # in the database with the Transform() function.
> > > > # Download from: http://www.remotesensing.org/proj
> > > > USE_PROJ=@USE_PROJ@
> > > > PROJ_DIR=@PROJ_DIR@
> > > > # Set USE_GEOS to 1 for GEOS spatial predicate and operator
> > > > # support (recommended).
> > > > # GEOS installation directory defaults to /usr/local,
> > > > # set GEOS_DIR environment variable to change it.
> > > > # GEOS allows you to do exact topological tests, such as
> > > > # Intersects() and Touches(), as well as geometry operations,
> > > > # such as Buffer(), GeomUnion() and Difference().
> > > > # Download from: http://geos.refractions.net
> > > > USE_GEOS=@USE_GEOS@
> > > > GEOS_DIR=@GEOS_DIR@
> > > > # Set USE_JTS to 1 if you have libjts installed.
> > > > USE_JTS=0
> > > > JTS_INCLUDES=@JTS_INCLUDES@
> > > > JTS_LIBDIR=@JTS_LIBDIR@
> > > > # Set USE_STATS to 1 for new GiST statistics collection support
> > > > # Note that this support requires additional columns in
> > > > # GEOMETRY_COLUMNS, so see the list archives for info or
> > > > # install a fresh database using postgis.sql.
> > > > # This option is useless for builds against PGSQL>=80 (stats
> > > > # are always gathered in that case, and you don't need additional
> > > > # columns in geometry_columns).
> > > > USE_STATS=1
> > > > # Set AUTOCACHE_BBOX to 0 if you want finer control over
> > > > # bounding box computation and caching for your geometries.
> > > > # If you do, bbox computattion strategies are listed in
> > > > # the file lwgeom/BBOXCACHE_BEHAVIOURS, but don't expect
> > > > # them to be easy nor consistent.
> > > > AUTOCACHE_BBOX=1
> > > > # Set USE_ICONV to 1 if you want the loader (shp2pgsql)
> > > > # to support UTF-8 output.
> > > > USE_ICONV=0
> > > > # PGSQL
> > > > PGCONFIG=@PGCONFIG@
> > @PGBEINCLUDES@/port/win32 @PGBEINCLUDES@/port/win32/arpa
> > > > else
> > > > PGFELIBS=@PGFELIBS@
> > > > endif
> > > > # Docbook
> > > > XSLBASE=@XSLBASE@
> > > > # Compilers
> > > > CC=@CC@
> > > > CXX=@CXX@
> > > > # Other programs
> > > > FLEX=@FLEX@
> > > > YACC=@YACC@
> > > > INSTALL=@INSTALL@ -c
> > > > INSTALL_DATA=$(INSTALL) -m 644
> > > > INSTALL_BIN=$(INSTALL) -m 755
> > > > INSTALL_LIB=$(INSTALL) -m 755
> > > > # PATHS
> > > > prefix=@prefix@
> > > > exec_prefix=@exec_prefix@
> > > > bindir=@bindir@
> > > > datadir=@datadir@
> > > > mandir=@mandir@
> > > > docdir=@docdir@
> > > > libdir=@libdir@
> > > > libexecdir=@libexecdir@
> > > > MODULE_INSTALLDIR=@MODULE_INSTALLDIR@
> > > > LPATH=@LPATH@
> > > > # DLL
> > > > DLSUFFIX=.dll
> > > > DLFLAGS=@DLFLAGS@
> > > > else
> > > > DLSUFFIX=@DLSUFFIX@
> > > > DLFLAGS=@DLFLAGS@
> > > > endif
> > > > # Use JTS instead of GEOS if available
> > > > ifeq ($(USE_JTS),1)
> > > > USE_GEOS=0
> > > > endif
> > > > # Test the version string and set the USE_VERSION macro
> > > > # appropriately.
> > > > VERSION=$(shell $(PGCONFIG) --version)
> > > > ifneq ($(findstring 7.1,$(VERSION)),)
> > > > USE_VERSION=71
> > > > else
> > > > ifneq ($(findstring 7.2,$(VERSION)),)
> > > > USE_VERSION=72
> > > > else
> > > > ifneq ($(findstring 7.3,$(VERSION)),)
> > > > USE_VERSION=73
> > > > else
> > > > ifneq ($(findstring 7.4,$(VERSION)),)
> > > > USE_VERSION=74
> > > > else
> > > > USE_VERSION=80
> > > > endif
> > > > endif
> > > > endif
> > > > endif
postgis/lwgeom/Makefile ]===================================================
> > > > include ../Makefile.config
> > > > include ../Version.config
> > > > # Default missing CXX variable to c++
> > > > ifeq ($(CXX),)
> > > > CXX = c++
> > > > endif
> > > > NAME=lwgeom
> > > > SHLIB =
> > > > SHLIB_LINK =
> > > > else
> > > > SHLIB =
> > > > endif
> > > > else
> > > > endif
> > > > override CFLAGS += -g -O2 -fexceptions
> > > > override CFLAGS += -fPIC
> > > > #override CFLAGS
> > += -I$(srcdir) -DFRONTEND -DSYSCONFDIR='"$(sysconfdir)"'
> > > > override CFLAGS += -DUSE_VERSION=$(USE_VERSION)
> > > > override CFLAGS += -DPOSTGIS_LIB_VERSION='"$(POSTGIS_LIB_VERSION)"'
> > > > override CFLAGS += -DPOSTGIS_SCRIPTS_VERSION='"$(SCRIPTS_VERSION)"'
> > > > override CFLAGS += -DPOSTGIS_BUILD_DATE='"$(POSTGIS_BUILD_DATE)"'
> > > > JTS_OBJ=lwgeom_nojts.o
> > > > ifeq ($(USE_GEOS),1)
> > > > override CFLAGS += -I$(GEOS_DIR)/include -DUSE_GEOS
> > > > GEOS_RULES=detect_geos_version
> > > > GEOS_WRAPPER=lwgeom_geos_wrapper.o
> > > > JTS_OBJ=lwgeom_geos.o
> > > > SHLIB_LINK += -lstdc++ -L$(GEOS_DIR)/lib -lgeos
> > > > endif
> > > > ifeq ($(USE_JTS),1)
> > > > override CFLAGS += -I$(JTS_INCLUDES) -DUSE_JTS
> > > > JTS_WRAPPER=lwgeom_jts_wrapper.o
> > > > JTS_OBJ=lwgeom_jts.o
> > > > SHLIB_LINK += -lgcj -ljts -lstdc++ -L$(JTS_LIBDIR)
> > > > endif
> > > > ifeq ($(USE_PROJ),1)
> > > > override CFLAGS += -I$(PROJ_DIR)/include -DUSE_PROJ
> > > > SHLIB_LINK += -L$(PROJ_DIR)/lib -lproj
> > > > endif
> > > > override CFLAGS +=
$(PGBEINCLUDES) -DAUTOCACHE_BBOX=$(AUTOCACHE_BBOX)
> > > > override CXXFLAGS := $(CFLAGS)
> > > > # memory debug for gcc 2.91, 2.95, 3.0 and 3.1
> > > > # for gcc >= 3.2.2 set GLIBCPP_FORCE_NEW at runtime instead
> > > > #override CXXFLAGS += -D__USE_MALLOC
> > > > # Add index selectivity to C flags
> > > > ifeq ($(USE_STATS),1)
> > > > override CFLAGS += -DUSE_STATS
> > > > endif
> > > > SA_OBJS=measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o
> > lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o
> > $(GEOS_WRAPPER) $(JTS_WRAPPER) wktunparse.o lwgparse.o wktparse.tab.o
> > lex.yy.o vsprintf.o
> > > > OBJS=$(SA_OBJS) liblwgeom.o lwgeom_pg.o lwgeom_debug.o
lwgeom_spheroid.o
> > lwgeom_ogc.o lwgeom_functions_analytic.o $(JTS_OBJ) lwgeom_inout.o
> > lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o
> > lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o
> > lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
> > lwgeom_triggers.o lwgeom_dump.o
> > > > #OTHERS=y.output lex.yy.c wktparse.tab.c wktparse.tab.h
lwpostgis.sql
> > > > OTHERS=y.output lwpostgis.sql ../lwpostgis.sql
postgis_geos_version.h
> > > > # Makefile targets
> > > > $(SHLIB): $(OBJS)
> > > > else
> > > > endif
> > > > mv -f y.tab.c wktparse.tab.c
> > > > mv -f y.tab.h wktparse.tab.h
> > > > lex.yy.c: wktparse.lex wktparse.tab.c
> > > > $(FLEX) -Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
> > > > lwgeom_jts_wrapper.o: lwgeom_jts_wrapper.cpp
> > > > lwgeom_geos_wrapper.o: lwgeom_geos_wrapper.cpp
> > > > lwgeom_geos.o: lwgeom_geos.c profile.h
> > > > lwgeom_jts.o: lwgeom_jts.c profile.h
> > > > lwgeom_nojts.o: lwgeom_nojts.c
> > > > lwgeom_functions_basic.o: lwgeom_functions_basic.c profile.h
> > > > # Shared library stuff
> > > > ../lwpostgis.sql: lwpostgis.sql
> > > > cp lwpostgis.sql ..
> > > > lwpostgis.sql: lwpostgis.sql.in
> > > > cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< | sed -e
's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POSTGIS_VERS
ION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POSTGIS_BUILD_DAT
> > E@/$(POSTGIS_BUILD_DATE)/g' | grep -v '^#' > $@
> > > > install: all install-lwgeom-lib install-lwgeom-scripts
> > > > install-lwgeom-scripts:
> > > > @mkdir -p $(datadir)
> > > > $(INSTALL_DATA) lwpostgis.sql $(datadir)/lwpostgis.sql
> > > > $(INSTALL_DATA) ../spatial_ref_sys.sql
$(datadir)/spatial_ref_sys.sql
> > > > #- This has been copied from postgresql and adapted
> > > > install-lwgeom-lib: $(SHLIB)
> > > > @mkdir -p $(MODULE_INSTALLDIR)
> > > > $(INSTALL_LIB) $< $(MODULE_INSTALLDIR)/$(SHLIB)
> > > > ifneq ($(PORTNAME), win)
> > > > ifneq ($(SHLIB), $(SHLIB_MAJOR))
> > > > cd $(MODULE_INSTALLDIR) && \
> > > > rm -f $(SHLIB_MAHOR) && \
> > > > ln -sf $(SHLIB) $(SHLIB_MAJOR)
> > > > endif
> > > > ifneq ($(SHLIB), lib$(NAME)$(DLSUFFIX))
> > > > rm -f $(SHLIB_BARE) && \
> > > > ln -sf $(SHLIB) $(SHLIB_BARE)
> > > > endif
> > > > endif # not win
> > > > uninstall-lib:
> > > > rm -f $(MODULE_INSTALLDIR)/$(SHLIB)
> > > > rm -f $(MODULE_INSTALLDIR)/$(SHLIB_MAJOR)
> > > > rm -f $(MODULE_INSTALLDIR)/$(SHLIB_BARE)
> > > > detect_geos_version:
> > > > sh ../geos_version.sh $(GEOS_DIR) > postgis_geos_version.h
> > > > uninstall-lwgeom-scripts:
> > > > rm -f $(datadir)/postgis/lwpostgis.sql
> > > > rm -f $(datadir)/postgis/spatial_ref_sys.sql
> > > > uninstall: uninstall-lib uninstall-lwgeom-scripts
> > > > clean-lib:
> > > > rm -f $(SHLIB) $(SHLIB_MAJOR) $(SHLIB_BARE)
> > > > clean distclean: clean-lib
> > > > rm -f *.o *.so *.a test $(OTHERS)
> > > > maintainer-clean: clean
> > > > rm -f lex.yy.c wktparse.tab.c wktparse.tab.h
> > > > liblwgeom_sa.o: liblwgeom.c
> > > > $(CC) -DSTANDALONE -o $@ -c $<
> > > > liblwgeom_sa.so: $(SA_OBJS) liblwgeom_sa.o
> > > > $(CC) -shared -o $@ $^
> > > > liblwgeom_sa.a: $(SA_OBJS) liblwgeom_sa.o
> > > > $(AR) -rc $@ $^
> > > > test: liblwgeom_sa.so liblwgeom_sa.a test.c
> > > > $(CC) -Wall -lm -g -o test test.c liblwgeom_sa.a
> > > > tsort:
> > > > lorder $(SA_OBJS) | tsort
> > > > ========================================[ postgis/loader/Makefile ]
> > > > # PostGIS Loader Makefile
> > > > SHELL = /bin/sh
> > > > subdir = contrib/postgis/loader
> > > > EXE =
> > > > UNAME = $(shell uname)
> > > > ifeq ($(findstring CYGWIN,$(UNAME)),CYGWIN)
> > > > EXE = .exe
> > > > endif
> > > > ifeq ($(findstring MINGW,$(UNAME)),MINGW)
> > > > EXE = .exe
> > > > endif
> > > > OBJS = shpopen.o dbfopen.o getopt.o
> > > > ifeq ($(USE_ICONV),1)
> > > > override CFLAGS += -DUSE_ICONV
> > > > endif
> > > > override CFLAGS := -g -Wall -I..
$(CFLAGS) -DUSE_VERSION=$(USE_VERSION)
> > > > all: shp2pgsql$(EXE) pgsql2shp$(EXE)
> > > > pgsql2shp.o: pgsql2shp.c
> > $(shell pg_config --libdir)/libpq.a -o $@
> > > > else
> > $(LDFLAGS) -o $@
> > > > endif
> > > > install: all
> > > > @mkdir -p $(bindir)
> > > > $(INSTALL_BIN) pgsql2shp$(EXE) $(bindir)/pgsql2shp$(EXE)
> > > > $(INSTALL_BIN) shp2pgsql$(EXE) $(bindir)/shp2pgsql$(EXE)
> > > > uninstall:
> > > > rm -f $(bindir)/pgsql2shp$(EXE)
> > > > rm -f $(bindir)/shp2pgsql$(EXE)
> > > > clean:
> > > > rm -f $(OBJS) shp2pgsql.o pgsql2shp.o shp2pgsql$(EXE)
pgsql2shp$(EXE)
> > > > TECHER Jean David
> > > > 01MAP
> > > > Tél: 04 67 45 60 27
> > > > _______________________________________________
> > > > postgis-users mailing list
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
