[postgis-devel] Re: [postgis-users] shp2pgsql segfault and gdb
strk at refractions.net
Mon Aug 29 15:40:22 PDT 2005
On Mon, Aug 29, 2005 at 02:45:40PM +0200, Jorg Heymans wrote:
> strk at refractions.net wrote:
> > What architecture are you running the loader from ?
> I tested on 2 hardware configs, both fail.
> - dual P3 , 750MB ram running slackeware 10
> - dual opteron 246, 4GB ram running gentoo (64bit). Note that on this
> architecture I get a slightly more descriptive errormessage before the
> segmentation fault :
> Shapefile type: Arc
> Postgis type: MULTILINESTRING[2]
> MULTILINESTRING 3065 as 1 vertices, set to NULL
> *** glibc detected *** double free or corruption (!prev):
> 0x000000000050d800 ***
> Aborted
Ok, I think I fixed the problem, could you test latest
revision from the pgis_1_0 branch of postgis CVS ?
This probably calls for release 1.0.5 ...
--strk;
