[postgis-devel] SnapToGrid and higher dimensions
strk at refractions.net
Fri Dec 2 05:19:52 PST 2005
On Fri, Dec 02, 2005 at 12:29:54PM +0100, Markus Schaber wrote:
> (Sorry, this mail was sent unfinished accidentally.)
> Hi, Strk,
> strk at refractions.net wrote:
> > A BOX4D type could do, representing grid cell prototype.
> > Unfortunately adding a new type would require users to dump/reload
> > to upgrade to postgis 1.1.0 (currenlty unneeded).
> I agree with you that a BOX4D is not worth the effort, although I think
> it is possible to add a completely new datatype without dump/reload. No
> old data has to be migrated (because their storage format will not
> change), we only have a bunch of new new and some changed definitions.
> > SnapToGrid(geometry input, point offset,
> > float8 xsize, float8 ysize, [float8 zsize], [float8 msize]);
> I think that this is a good solution. Sematically, it is a good decision
> to represent the offset by a Point.
I've implemented this, but dropped the optionality of higher dimension
cell sizes. If we want to provide defaults for sizes we'll end up
with conflics as in:
SnapToGrid('POINT(9 11)', 10, 10);
SnapToGrid('POINT(9 11)', 'POINT(0 0)', 10);
See if you can live with it.
remember to run postgis_proc_upgrade.pl to enable this.
Also, rember to feed postgis_proc_upgrade.pl the name of schema in which
postgis is installed (or you might end up with duplicated functions)
--strk;
/"\ ASCII Ribbon Campaign
\ / Respect for open standards
X No HTML/RTF in email
/ \ No M$ Word docs in email
