[postgis-devel] New polygon constructors (was: OGC polygon constructors)
Michael Fuhr
mike at fuhr.org
Mon Dec 12 10:29:23 PST 2005
On Mon, Dec 12, 2005 at 06:46:02PM +0100, strk at refractions.net wrote:
> Regress test has been added for the tree functions.
Regression is failing again on Solaris:
./run_test: syntax error at line 64: `SKIPPED=$' unexpected
As I mentioned in another report, /bin/sh on Solaris is a traditional
Bourne Shell so expressions like this don't work:
SKIPPED=$(($SKIPPED+1))
I replaced such expressions with
SKIPPED=`expr $SKIPPED + 1`
After that the tests succeeded. The system is:
PostgreSQL 8.2devel on sparc-sun-solaris2.9, compiled by GCC gcc (GCC) 3.4.2
POSTGIS="1.1.0CVS" GEOS="3.0.0-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS DBPROC="0.3.1" RELPROC="0.3.1"
Michael Fuhr
