[postgis-devel] postgis_version() alias of postgis_full_version()?
Paul Ramsey
pramsey at refractions.net
Thu Dec 15 15:51:55 PST 2005
This worries me, I don't want a small change in number format to
break backwards compatibility on our clients...
If we go to:
1.1.1 USE_GEOS USE_PROJ
Are we busted? We are going to retain the USE_* strings, but make
them dynamically tested on actual library presence, so they will not
get inaccurate over time. That leaves the fluffing of the number as
the only change to postgis_version(). Does that still break things?
P
On 15-Dec-05, at 1:36 PM, Dale Lutz wrote:
> The version info should continue to work reasonably well with a minor
> tweak to get the additional version digit.
