[postgis-devel] 1.1.0 closed - Release on 21 - call for tests
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Sun Dec 18 03:31:36 PST 2005
Hi strk,
Here are the MingW tests under PostgreSQL 8.1 (regression diffs attached).
It looks like the majority could be caused by different CR/LF endings
between Windows/Unix, but there are also a few others that have me puzzled.
$ make test
make -C lwgeom
make[1]: Entering directory `/home/mca/postgis/postgis-cvs/lwgeom'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/mca/postgis/postgis-cvs/lwgeom'
make -C regress test
make[1]: Entering directory `/home/mca/postgis/postgis-cvs/regress'
PostgreSQL 8.1.0 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.2
(mingw-special)
Postgis 1.1.0
- 2005-12-18 10:29:48
GEOS: 2.2.1-CAPI-1.0.1
JTS:
PROJ: Rel. 4.4.9, 29 Oct 2004
Running tests
regress: Failed (diff /tmp/regress_regress_diff_480)
regress_index: Failed (diff /tmp/regress_regress_index_diff_480)
lwgeom_regress: Failed (diff /tmp/regress_lwgeom_regress_diff_480)
regress_lrs: Failed (diff /tmp/regress_regress_lrs_diff_480)
removepoint: Failed (diff /tmp/regress_removepoint_diff_480)
setpoint: Failed (diff /tmp/regress_setpoint_diff_480)
regress_ogc: Failed (diff /tmp/regress_regress_ogc_diff_480)
regress_bdpoly: Failed (diff /tmp/regress_regress_bdpoly_diff_480)
regress_proj: Failed (diff /tmp/regress_regress_proj_diff_480)
Run tests: 9
Successful: 0
Failed: 9
make[1]: Leaving directory `/home/mca/postgis/postgis-cvs/regress'
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20051218/bef2f1c2/attachment.bin>
