[postgis-devel] 1.1.0 closed - Release on 21 - call for tests
Havard Tveite havard.tveite at umb.no
Thu Dec 22 01:55:27 PST 2005
configure now runs smoothly on Solaris 2.7.
(and all 9 tests are OK)
Haavard
strk at refractions.net wrote:
> I completely dropped usage of AWK in the configure script,
> parsing of `pg_config --configure` now happens in a centralized
> place.
> Tested successfully on GNU/Linux and FreeBSD 4.2.
> Would you guys test on Solaris 7 and 9 ?
> TIA
> --strk;
> On Wed, Dec 21, 2005 at 09:21:28AM -0700, Michael Fuhr wrote:
>>On Wed, Dec 21, 2005 at 04:32:25PM +0100, Havard Tveite wrote:
>>>Solaris 2.7:
>>>configure now runs, but there is still a problem with
>>>PGTEMPLATE="`${PGCONFIG}...
>>>checking which template to use... ./configure: syntax error at line 6: `end
>>>of file' unexpected
>>>./configure: syntax error at line 39: `similar' unexpected
>>>./configure: syntax error at line 3: `fi./configure: syntax error at line
>>>3: `end of file' unexpected
>>>' unexpected
>>I don't see anything like this on Solaris 9 but I have been getting
>>the following:
>>checking which template to use... awk: syntax error near line 1
>>awk: illegal statement near line 1
>>awk: bailing out near line 1
>>solaris
>>I haven't paid much attention to these errors since it seems to
>>work, but on my system the errors can be eliminated by adding
>>AC_PROG_AWK to configure.in and using $AWK instead of awk (configure
>>then uses nawk instead of awk; awk on Solaris is an ancient version).
>>Michael Fuhr
>>_______________________________________________
>>postgis-devel mailing list
>>postgis-devel at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 14, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt
