[postgis-devel] Re: [postgis-users] Postgis on Solaris - gdb details
strk at refractions.net
Thu Feb 10 02:45:49 PST 2005
I've went through the code and made sure 'unsigned char' is used
wherever 'octet' is actually meant.
See if this fixes your problem.
For all users testing RC releases: please give current CVS a check.
--strk;
On Thu, Feb 10, 2005 at 10:28:03AM +0100, strk at refractions.net wrote:
> On Wed, Feb 09, 2005 at 07:07:53PM -0800, Ionut Iordache wrote:
> > Hello,
> > I found a more specific reason why my installation crashes:
> > Following is an excerpt from running gdb against the backend and
> > breaking at a point close to where it crashes after executing " select
> > X(geom) from gtest;":
> > Breakpoint 2, LWGEOM_x_point (fcinfo=0xffbed600) at lwgeom_ogc.c:528
> > 528 if ( point == NULL ) PG_RETURN_NULL();
> > (gdb) print point
> > $1 = (LWPOINT *) 0x37f188
> > (gdb) print point->point
> > $2 = (POINTARRAY *) 0x37f248
> > (gdb) print point->point->dims
> > $3 = 0 '\0'
> > (gdb) print point->point->npoints
> > $4 = 1
> > (gdb) n
> > 531 p = (POINT2D *)getPoint(point->point, 0);
> > (gdb) print p
> > Cannot access memory at address 0xfffffff0
> > (gdb) n
> > 533 PG_RETURN_FLOAT8(p->x);
> > (gdb) n
> > Program received signal SIGSEGV, Segmentation fault.
> > LWGEOM_x_point (fcinfo=0xffbed600) at lwgeom_ogc.c:533
> > (gdb)
> > My understanding is that the POINTARRAY structure passed to the "getPoint"
> > function is somehow invalid... One obvious thing that I noticed (and I
> > might be way off track here, it's my first time reading through this
> > code...) is that the dimension is always 0, where this is noted in
> > the source files:
> > /size of point represeneted in the POINTARRAY
> > // 16 for 2d, 24 for 3d, 32 for 4d
> > int
> > pointArray_ptsize(const POINTARRAY *pa)
> > return sizeof(double)*TYPE_NDIMS(pa->dims);
> > I also tested with LINESTRING and pointArray_ptsize will always return
> > 0 here...
> POINTARRAY.dims is used as a bitfield for hasZ and hasM flags. 0==2d.
> Can you print value of pa->serialized_pointlist ?
> Return from getPoint should be an offset from there
> (+16*pointN for a 2d ptarray, same address X)
> --strk;
> > Any help is greatly appreciated!
> > Tuesday, February 8, 2005, 2:40:23 PM, you wrote:
> > II> Hello,
> > II> I've been having problems for a while with Postgis on Solaris 8
> > II> (sparc). I have tried various combinations of Postgresql 8.0.1, 7.4.6
> > II> with Postgis versions 0.9.1 and up.
> > II> The problem is that after the packages compile relatively without
> > II> hassle, I can't use any postgis spatial function without crashing the
> > II> database.
> > II> For example, I create an empty database, add the lwpostgis.sql
> > II> extension, create a spatial table with point geometry, insert one row
> > II> into the table... up to this point everything is fine... when I run
> > II> "select astext(geom) ..." the point shows up correctly, but when I
> > II> execute "select X(geom) ..." the backend crashes:
> > II> server closed the connection unexpectedly
> > II> This probably means the server terminated abnormally
> > II> before or while processing the request.
> > II> The connection to the server was lost. Attempting reset: Failed
> > II> I compiled with LDFLAGS="-lstdc++ -lgcc" and gcc 3.4.1.
> > II> My gcc installation is configured as follows:
> > II> Reading specs from
> > II> /a/perry/data/pkgs3/local/bin/../lib/gcc/sparc-sun-solaris2.8/3.4.1/specs
> > II> Configured with: ../configure --with-as=/usr/ccs/bin/as
> > II> --with-ld=/usr/ccs/bin/ld --disable-nls
> > II> Thread model: posix
> > II> gcc version 3.4.1
> > II> The compiler uses Sun's linker and I was wondering if this is part of
> > II> the problem... When I try to compile with GNU's ld, I get a
> > II> "option -dn and -P are incompatible" linker error.
> > II> The logs are not showing anything interesting, even with the highest
> > II> debug option set...
> > II> I also tried to debug the backend, but I get this error in gdb:
> > II> Reading symbols from /usr/local/lib/libstdc++.so.6...Error
> > II> while reading shared library symbols:
> > II> Dwarf Error: Cannot handle DW_FORM_strp in DWARF reader.
> > II> So, is anyone else using lwgeom Postgis on Solaris 8? Did you compile
> > II> gcc from scratch, or used the binaries from sunfreeware.com ?
> > II> Any ideas of what might go wrong with my installation?
> > II> Many thanks,
> > II> -----------------------------------------------
> > II> Dorel Ionut Iordache - <ionut at eps.berkeley.edu>
> > II> UC Berkeley - Earth & Planetary Science Dept.
> > II> _______________________________________________
> > II> postgis-users mailing list
> > II> postgis-users at postgis.refractions.net
> > II> http://postgis.refractions.net/mailman/listinfo/postgis-users
> > Best regards,
