[postgis-devel] PostGIS RC1/2 and QGIS
Carl Anderson
carl.anderson at co.fulton.ga.us
Thu Feb 10 06:30:35 PST 2005
strk at refractions.net wrote:
>>>the offending statement that QGIS is making is
>>>declare qgisf binary cursor for select oid,asbinary(shape,'NDR') as
>>>qgs_feature_geometry from case6 where shape &&
>>>GeometryFromText('BOX3D( 2288006.545455 1472366.000000,
>>>2291123.454545 1475094.000000)'::box3d,102667)
>>it can be helped as (drop geometryfromtext and add setsrid )
>>qgs_feature_geometry from case6 where shape && setsrid('BOX3D(
>>2288006.545455 1472366.000000, 2291123.454545
>Are mapserver and postgis runnign on the same host (just to exclude
>byte ordering issues) ?
>--strk;
qgis -WinXp (intel P4)
Postgis - Linux (intel P3)
mapserver 4.4.1 ( intel P3)
mapserver 4.4.1 is working --- it uses this statement
DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(shape)),'NDR'),geo_oid::text from
z2.case6 WHERE shape && setSRID('BOX3D(2228328.35384
1482507.61292179,2230568.16919753 1483897.32106711)'::BOX3D,
find_srid('','z2.case6','shape') )
I'm capturing these messages by enabling statement logging on the
postgres server
>>>>On Wed, Feb 09, 2005 at 08:18:42PM -0900, Gary Sherman wrote:
>>>>>On Wed, 2005-02-09 at 10:33 +0100, strk at refractions.net wrote:
>>>>>>On Tue, Feb 08, 2005 at 06:53:44PM -0900, Gary Sherman wrote:
>>>>>>>The latest release candidates of PostGIS do not work with QGIS.
>>>>>>>Currently we use a binary cursor, using the asbinary function to
>>>>>>>fetch
>>>>>>>the features. I took a quick look around and didn't find any
>>>>>>>documentation on the changes in lwgeom and the appropriate way to
>>>>>>>read
>>>>>>>features.
>>>>>>>Can anyone point me to a document or give me a hint?
>>>>>>Can you give *us* an hint ? We're hunting exactly this bug. Reports
>>>>>>are multipolygons
>>>>>>work while polygons don't. Can you confirm this ?
>>>>>>Can you provide sample data exploiting the bug ?
>>>>>I am unable to display any data type (point, linestring, polygon, or
>>>>>multipolygon) in QGIS.
>>>>>I have not had time to step through the source in debug to determine
>>>>>the
>>>>>problem. A dump file of one of the polygon layers used for testing is
>>>>>available at http://qgis.org/lakes_dump.dmp.bz2 (this was dumped with
>>>>>the -d option).
>>>>>-gary
>>>>Thank you gary. I've tested your data against the wkbtester prog
>>>>attached in my previous mail. It reports no difference between HWGEOM
>>>>binary cursor and LWGEOM binary cursor !
>>>>The program opens a binary cursor for:
>>>>asbinary(force_2d(force_collection(geom))), does qgis do the same ?
>>>>--strk;
>>>>>_______________________________________________
>>>>>postgis-devel mailing list
>>>>>postgis-devel at postgis.refractions.net
>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>>>This message has been scanned for viruses and
>>>>dangerous content for Fulton County by DefendMail, and is
>>>>believed to be clean.
>>Carl Anderson
>>GIS Manager Fulton County, Georgia
>>404.730.8026
Carl Anderson
404.730.8026
