[postgis-devel] PostGIS RC1/2 and QGIS
strk at refractions.net
Fri Feb 11 09:46:51 PST 2005
On Fri, Feb 11, 2005 at 08:10:49AM -0900, Gary Sherman wrote:
> On Thu, 2005-02-10 at 09:30 -0500, Carl Anderson wrote:
> >mapserver 4.4.1 is working --- it uses this statement
> >DECLARE mycursor BINARY CURSOR FOR SELECT
> >asbinary(force_collection(force_2d(shape)),'NDR'),geo_oid::text from
> >z2.case6 WHERE shape && setSRID('BOX3D(2228328.35384
> >1482507.61292179,2230568.16919753 1483897.32106711)'::BOX3D,
> >find_srid('','z2.case6','shape') )
> I tried this syntax in QGIS and it does not allow the features to be
> drawn. The attribute table is populated with the data from the table so
> the cursor (both old and new syntax) is working.
> From this I gather the problem is in the way QGIS interprets the binary
> data for the features.
> -gary
This doesn't explain why it was working against postgis-0.x ...
Can you manually run the query and actually get results for the
geometry column ? Can you try with a newly created database
and the latest postgis CVS snapshot ?
--strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
