[postgis-devel] Re: [JDBC] PGConnection vs. Connection
Markus Schaber
schabios at logi-track.com
Fri Feb 11 12:51:29 PST 2005
Hi, Oliver,
Oliver Jowett schrieb:
>> - Prodiding a patch that is to be applied manually (rsp. by the debian
>> package build process) when building for 7.2. (this is our "current
>> practice").
> That seems the simplest approach. Both the 7.2 driver and server are
> truely ancient now -- I think having to manually apply a patch if you
> want to run against them isn't unreasonable.
I know that it is truely ancient, but for the PostGIS JDBC extension
developers, there are three reasons to support it: PostgreSQL itsself
still supports 7.2, PostGIS C code supports it, and Debian sta(b)le
comes with it.
>> - Using reflection. This could allow us per run-time distinction to use
>> o.p.PGConnection.addDataType(Class) when running against pgjdbc 8.0,
>> o.p.PGConnection.addDataType(String) against 7.3/7.4, and
>> o.p.Connection.addDataType(String) against 7.2. This way we could ship
>> a single postgis.jar that runs against all pgjdbc versions.
> That seems the most flexible approach, but reflection can be a pain to
> deal with. For the packaging case, if you are going to build "PostGIS
> for 7.2" and "PostGIS for 8.0" as separate packages then there doesn't
> seem like much advantage to having a single PostGIS build/jar anyway.
The reflection approach and the approach using our own files to compile
against have the advantage that we do not need to create different jars
for different jdbc versions, so the user does not have to bother which
one to use. This is why we did begin to think about them at all - make
it easy for the user. This is mainly for users that download their
postgis.jar from somewhere and drop it into their classpath, not for the
ones that automagically get their things resolved by .deb/.rpm package
system.
Markus
