[postgis-devel] Geos_noop memory leak?
strk at refractions.net
Thu Feb 17 08:04:48 PST 2005
On Thu, Feb 17, 2005 at 04:23:53PM +0100, Markus Schaber wrote:
> Hi,
> I think I might have found a memory leak in geos_noop.
GEOSnoop does nothing but converting geometries:
PostGIS->GEOS->PostGIS
If it leaks then *all* geos functions will leak.
If you're using GNU's libstdc++ >= 3.0 try setting
GLIBCPP_FORCE_NEW=1 in the environment, this would
disable late-deallocation, which is a *feature* of
the library.
--strk;
> This is my postmaster backend process after calling some non-geos GIS
> functions:
> PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
> 6870 postgres 25 0 23784 8700 7760 S 0.0 0.8 0:35.81 postmaster
> All three of VIRT, RES and SHR increased a lot during running the query,
> and dropped again when the query was finished. There is a small increase
> in RES and SHR memory usage after the _first_ call of each function,
> which seems to be caused by PostgreSQL loading the C function into
> memory. The memory usage keeps constant for repeated calls of the same
> function, or alternatinly calling already-initialized functions.
> Now the same process after calling "select geosnoop(geom) from adminbndy1;":
> 6870 postgres 25 0 138m 123m 7800 S 0.0 12.3 1:40.91 postmaster
> And after issuing the query a second time:
> 6870 postgres 25 0 248m 233m 7800 S 0.0 23.1 2:07.31 postmaster
> Can anyone reproduce this? Does this occur with other GEOS functions, too?
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
