[postgis-devel] Geos_noop memory leak?
strk at refractions.net
Fri Feb 18 00:30:29 PST 2005
Thanks Markus. I've found and fixed the leak.
--strk;
On Thu, Feb 17, 2005 at 07:12:59PM +0100, Markus Schaber wrote:
> Hi, strk,
> strk at refractions.net schrieb:
> >>I think I might have found a memory leak in geos_noop.
> > GEOSnoop does nothing but converting geometries:
> > PostGIS->GEOS->PostGIS
> > If it leaks then *all* geos functions will leak.
> That's bad. I initially thought there may be some missing deallocation
> in geosnoop().
> > If you're using GNU's libstdc++ >= 3.0 try setting
> > GLIBCPP_FORCE_NEW=1 in the environment, this would
> > disable late-deallocation, which is a *feature* of
> > the library.
> Hmm, I have:
> /usr/lib/gcc-lib/i486-linux/3.3.5/libstdc++.so
> /usr/lib/libstdc++-3-libc6.2-2-2.10.0.so
> /usr/lib/libstdc++-libc6.1-1.so.2
> /usr/lib/libstdc++-libc6.2-2.so.3
> /usr/lib/libstdc++.so.5
> /usr/lib/libstdc++.so.5.0.7
> /usr/lib/libstdc++.so.6
> /usr/lib/libstdc++.so.6.0.3
> I tried your setting in postmaster.env (which is proved to get passed to
> postmaster because I use it to set additional PGDATA directories),
> however, the leak still seems to exist.
> When using \connect to go to a different database, the memory comes
> back. Even using \connect to reconnect to the same database, the memory
> is freed. This may be due to some radical cleanup of all allocated memory.
> There is no difference whether I use autocommit, or BEGIN/COMMIT or
> BEGIN/ABORT.
> I tried to find a short query that illustrates the problem. The
> following query does leak about 10M on every call on my machine (i386):
> select npoints(buffer('POINT(0 0)',1,100000));
> Note that the npoints() is just to avoid sending this much output to the
> client. I also tried the example on 0.9 which seems not to suffer from
> this problem.
> HTH,
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
