[postgis-devel] release status
strk at refractions.net
Mon Feb 21 08:17:04 PST 2005
On Mon, Feb 21, 2005 at 04:01:35PM -0000, Mark Cave-Ayland wrote:
> The -fPIC warnings are a little noisy but I don't think they will affect the
> resulting library. There are a couple of min/maxs that need to be replaced
> with the PostGIS equivalent along with a change for the 'byte' type.
> Interestingly enough, shp2pgsql/pgsql2shp show an issue trying to access the
> getopt() function too. I'm not sure about the vsprintf() error, although it
> looks as if it may be a bug in MingW.
byte has been changed to uchar, which is typedef'ed in liblwgeom.h.
lwgeom_estimate.c has been changed to use LW_MIN and LW_MAX macros.
The getopt() function is declared in getopt.h, but only when used
against GNU C lib, to avoid clashes on systems defining it in
stdlib.h (read comment there).
vsprintf is declared in compat.h, which is not included by vsprintf.c
itself.
Actually none of the above was a problem... anyway, 2/4 have been fixed.
--strk;
> Kind regards,
> Mark.
> WebBased Ltd
> South West Technology Centre
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 791021
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
