[postgis-devel] PATCH: New positional operators based on Y position of bounding boxes
strk at refractions.net
Tue Jan 11 03:23:08 PST 2005
Happy New Year Mark!
That's Good Stuff to me.
Just... can vv &v ^^ &^ be used as operator names ?
--strk;
On Tue, Jan 11, 2005 at 11:11:58AM -0000, Mark Cave-Ayland wrote:
> Happy New Year everyone! :)
> Here is a patch against CVS that addresses a slightly strange omission from
> the operators included with PostGIS. One of our import scripts had
> accidentally created some geometries with very large Y coordinates (e.g.
> POINT(0 1E20)) and in order to delete these rows, I had to select
> geometeries above a certain Y-coordinate which is currently not implemented
> in PostGIS as an indexable operator (I gave up waiting for over half an hour
> for a SELECT... ORDER BY... to complete on a multi-million row table,
> whereas it is already possible to do this in seconds on the X-axis using the
> << and >> operators).
> This patch implements the following additional operators for PostGIS, with
> the ability to use a GiST index where one exists:
> A <<| B
> The bounding box of A is strictly below the bounding box of
> B
> A &<| B
> The bounding box of A vertically overlaps or is below the
> bounding box of B
> A |>> B
> The bounding box of A is strictly above the bounding box of
> B
> A |>& B
> The bounding box of A vertically overlaps or is above the
> bounding box of B
> (to make sense of these operators, it may help to tilt your head 90 degrees
> to the right, where the | character represents the X-axis).
> I've posted this for review instead of applying directly since I know Paul
> was considering reducing the number of operators included in PostGIS. I have
> done some simple tests using both sequential and index scans, and confirmed
> that the new operators return the expected results. Comments anyone?
> Kind regards,
> Mark.
> WebBased Ltd
> South West Technology Centre
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 791021
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
For standing up against patentability of software,
Thank You, Poland!
Read the intervention: http://kwiki.ffii.org/ConsPolon041221En
Send your thanks: thankyoupoland.info
Read/do more: http://www.noepatents.org/
