[postgis-devel] isvalid() error
strk at refractions.net
Thu Jan 13 23:22:57 PST 2005
PostGIS always allowed polygon rings with 3 points.
In this case it disagrees with GEOS about this.
Also, PostGIS does not allow 0 points.
Should we enforce GEOS constraints or just have isvalid
return FALSE in these cases ?
--strk;
On Thu, Jan 13, 2005 at 05:07:59PM -0500, Carl Anderson wrote:
> need to test for ring counts prior to sending to GEOS
> select isvalid(geometry('POLYGON((0 0,0 1,0 0))'));
> NOTICE: IllegalArgumentException: Number of points must be 0 or >3
> ERROR: POSTGIS2GEOS conversion failed
> Carl Anderson
> GIS Manager Fulton County, Georgia
> carl.anderson at co.fulton.ga.us
> 404.730.8026
> This message has been scanned for viruses and
> dangerous content for Fulton County by DefendMail, and is
> believed to be clean.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
For standing up against patentability of software,
Thank You, Poland!
Read the intervention: http://kwiki.ffii.org/ConsPolon041221En
Send your thanks: thankyoupoland.info
Read/do more: http://www.noepatents.org/
