[postgis-devel] autoconf
strk at refractions.net
Mon Jan 24 06:31:04 PST 2005
On Mon, Jan 24, 2005 at 03:10:19PM +0100, TECHER Jean David wrote:
> strk:
> did you update the doc for autoconf???
I need some more success stories before that.
--strk;
> TECHER Jean David
> Responsable Informatique 01MAP
> e-mail: davidtecher at yahoo.fr
> Bureau: 04 67 45 60 27
> Portable: 06 85 37 36 75
> site perso : http://techer.pascal.free.fr/postgis/
> site pro: http://www.01map.com/download/
> K-S:"The greatest trick the devil pulled off was convincing people he didn't
> exist"
> ----- Original Message -----
> From: <strk at refractions.net>
> To: <postgis-devel at postgis.refractions.net>
> Sent: Monday, January 24, 2005 2:47 PM
> Subject: [postgis-devel] autoconf
> > I've added in CVS an initial configure script, aimed at
> > reducing format errors in Makefile.config.
> > Run autoconf to obtain a configure from configure.in.
> > Then you can use ./configure \
> > --with-geos=path_to_geos-config \
> > --with-proj=PROJ_DIR \
> > --with-pgsql-src=PGSQL_SRC_DIR
> > Note that so far there are no autodetects, just checks on
> > provided paths. As before environmental variables are honoured
> > (at configure time, not later).
> > The configure script will print a summary of configured paths.
> > Comments welcome
> > --strk;
> > For standing up against patentability of software,
> > Thank You, Poland!
> > Read the intervention: http://kwiki.ffii.org/ConsPolon041221En
> > Send your thanks: thankyoupoland.info
> > Read/do more: http://www.noepatents.org/
> > postgis-devel mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
