[postgis-devel] RC2 ?
Paul Ramsey
pramsey at refractions.net
Tue Jan 25 08:11:30 PST 2005
Jump over autoconf? Jump over *to* autoconf?
I think changing the build over to autoconf should wait until 1.1.
I am stoked for an RC2.
Paul
On 25-Jan-05, at 6:20 AM, strk at refractions.net wrote:
> This is a list of changes since RC1 is out:
> - More correct STABLE, IMMUTABLE, STRICT uses in lwpostgis.sql
> - GEOMETRYCOLLECTION(EMPTY) syntax support for backward
> compatibility
> - faster and more robust loader (both i18n and not)
> - faster binary outputs
> - bug fix in pointarray box3d computation
> - initial autoconf script
> - bug fix in distance_spheroid definition
> - stricter OGC WKB constructors
> - stricter OGC WKT constructors
> - bug fix in transform() missing to update bbox cache
> What do you think about an RC2 release ?
> Also, do you think we should jump over autoconf ?
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
